Suspension Sway Bars OMG
Old Jun 20, 2011 | 04:44 PM
FUBSZ's Avatar
FUBSZ
Sway Bars OMG
I was looking for someone to install the sway bars i just got and they quoted me 300$ to install ! and the sways cost less than 200 is that too much or is it normal , because they said its a minimum 6 hr job .
Old Jun 20, 2011 | 04:59 PM
slinger688's Avatar
slinger688
You have to drop the rear subframe. It should take around two hours and less if you have a lift.
Old Jun 20, 2011 | 05:00 PM
FUBSZ's Avatar
FUBSZ
they have lifts :S
Old Jun 20, 2011 | 05:23 PM
slinger688's Avatar
slinger688
And even less if they have done it before. Perhaps you can check with your local Mini club to see where others have brought their cars to.
dannyhavok's Avatar
dannyhavok
It cost me around $150 to have mine installed at my local tire place. They had a book time of about 3 hours for it. I had them on the phone before it was on the lift, I was in the shop 70m later and it was done and parked, so I know it only took them an hour.. they charged me for 90 minutes. Split the difference I guess.
Old Jun 20, 2011 | 05:24 PM
Eclipse11S's Avatar
Eclipse11S
You gotta look around and get Quotes.
I got a quote for coilovers and sway for $1200 Labor only. LMAO
Old Jun 20, 2011 | 05:25 PM
automan21's Avatar
automan21
Do it yourself man. Its cheaper, more rewarding and gives you a chance to get to know how things work. Dont be scared.
Old Jun 20, 2011 | 05:26 PM
dannyhavok's Avatar
dannyhavok
The dealer quoted me something like $1400 to install springs and a swaybar :/
Old Jun 20, 2011 | 05:54 PM
Eclipse11S's Avatar
Eclipse11S
The quote I got wasn't a dealer.
He was recommended by fellow nam'ers.
After I talked to him for abit and told him others shops are charging about 3-3.5 hrs,he then says Oh we can work something out.
I was still polite but laughing inside and told him I'll think about it.
Old Jun 20, 2011 | 05:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We only charge $100 here at the shop for a rear, but the front is a lot more involved if your doing it too.
Where are you located, maybe we can help you find a MINI shop that may be more in line.
Old Jun 20, 2011 | 07:43 PM
onasled's Avatar
onasled
Hmm... you did write "sway bars" If it's a quote for front and rear then that may not be that bad. Front's are a bit of a PIA
Old Jun 20, 2011 | 07:52 PM
dboard7's Avatar
dboard7
i just had mine installed with my torque arm insert by a friends friend and i helped him a little bit, more to learn and hold things in place, but i just gave him $40 as a thank you it wasn’t that complicated at all id recommend taking the day with a couple buddies and give it a try take your time and be careful. Save the money for more mods!
Old Jun 20, 2011 | 08:10 PM
minimike21's Avatar
minimike21
ya rear sway bar isnt to hard to install... i mean you need a jack and jack stands but if you have a few tools and that no prob!
Old Jun 21, 2011 | 07:21 AM
Cole9953's Avatar
Cole9953
I knocked mine out in 1:20 from jacking the the car up to clean up and test drive, by my self. the install proses is very simple, the most difficult part was a few bolts that didn't want to let go.
Cars are just nuts and bolts.... take it apart and put it back.
this philosophy has gotten me through cam and tranny swaps on my truck, and motor swaps/ builds to my old honda.
there isn't much an average guy can't do with basic tools and some jack stands.
Old Jun 21, 2011 | 07:31 AM
SMOG's Avatar
SMOG
Alliance Member
Yep, did mine by myself in less than 2hrs with a floor jack and 2 jackstands. Correct about doing the front, way more involved!
S.
YaTuSabe
Aug 23, 2018 11:41 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
mauiguyharry
Oct 8, 2015 06:53 PM
