R50/53 Stiff/sticky gearshift
Old Jun 17, 2011 | 08:05 AM
chrisneal's Avatar
chrisneal
In November 2010 I bought a 20 year old Volvo 740 to use as my daily driver, so that I can stop putting so many miles on my 2005 MC. Between then and now, I've driven my Cooper less than 1,000 miles. Over the winter I garaged it and only drove it once a month or so, and I was an idiot and didn't research adding crap to the gas or doing other things that you should do when storing a car. The battery died (it was 6 years old anyway), and I replaced it. This winter I'll be better.
Anyway, I've been driving it more again, and it feels like driving a Porsche 911 compared to the Volvo. Here's the problem, though. The manual gearshift is extremely sticky and tough to manipulate. If I move the stick all the way to the left or right, it stays there rather than returning to neutral position. I was hoping that it would loosen up with use, but no dice. It was fine before and during the winter, even up until this spring.
Any idea what the issue might be, and whether it's something that I might be able to address on my own?
Old Jun 17, 2011 | 08:40 AM
Filmy's Avatar
Filmy
Do a search for lubricating shifter cables.
Old Jun 17, 2011 | 08:58 AM
chrisneal's Avatar
chrisneal
Thanks! Most of the posts I saw were from MCS owners; any idea if the shifter cables are just as accessible under the MC hood? I wouldn't even know where to look for them.
Old Jun 17, 2011 | 09:02 AM
Filmy's Avatar
Filmy
You have to pull the air intake box. They're underneath.
Old Jun 17, 2011 | 09:05 AM
chrisneal's Avatar
chrisneal
OK, cool. That I can do, and have done. Thanks again!
Maybe this is a good time to stick a cone filter in there...
Old Jun 18, 2011 | 07:06 AM
miniwangja's Avatar
miniwangja
similar thing happened to me.
it was rust on the connecting brackets.
WD-40 fixed the problem. =)
Old Jun 20, 2011 | 03:19 PM
Filmy's Avatar
Filmy
I agree that WD-40 can handle some quick-fix lubrication issues. BUT...
The "WD" part is for water displacement, not lubrication. I always advise against using WD-40 for lube. (I tried it once for my squeaky blower motor fan and almost caught the car on fire!)
PB Blaster might loosen the rusty/stuck brackets you speak of, but the shifter cable assemblies need grease to fight the elements - that's all there is to it.
ltemup4650
Jul 17, 2024 04:01 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Mini-Hype
Aug 17, 2015 06:32 AM
blacter
Feb 15, 2010 06:36 PM
