R50/53 Brake sensor went off--how many miles left until I need replacement?
Old Jun 16, 2011 | 08:18 PM
MC2005s's Avatar
MC2005s
Light came on yesterday, called BMW today and they said once the light is lit up that I have 1-2k mi left before I need to take it in. Is it more? Less?
I searched and tried to find this answer but no luck. Thanks
Old Jun 16, 2011 | 08:51 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It really depends on how you drive, but the average person gets 1-2k miles before the pads are metal to metal once the light comes on.
FYI Since the light came on you have to replace that sensor. If you need pads we'll help you out.
Old Jun 17, 2011 | 05:43 AM
cristo's Avatar
cristo
Alliance Member
Might want to just peek at the pads to make sure they're not wearing too unevenly - they're usually
pretty close to each other, however.
There are 2 pads with sensors and 6 pads without sensors.
One or more of those 6 could be closer to metal on metal than the sensor equipped ones.
Old Jun 17, 2011 | 05:45 AM
AXO's Avatar
AXO
I just replaced my pads after my sensor went off. I would say there was approximately an 1/8" of pad left. I would roughly say 1,000 max.
Old Jun 17, 2011 | 08:31 AM
Filmy's Avatar
Filmy
When looking at your brake pads, you should also figure out if both axles (front & rear) need replacement, or just one. The front brakes do about 70% of the work, so it's more likely it's just your fronts - depending on previous brake service, that is.
Also, your rotors may well be good for another cycle of pads so don't let anyone force new rotors on you, and don't waste them by putting off pad replacement and getting metal-to-metal. Brake pads are inexpensive and easy to replace.
But if you're willing to let the dealer assault you on a simple brake service, you probably don't want cost savings advice.
Toolman
Jan 20, 2016 06:50 AM
marendt428
Nov 14, 2015 10:03 AM
squawSkiBum
Oct 2, 2015 09:21 AM
marendt428
Aug 8, 2015 04:44 AM
