Help! intake breather tube/valve cover install
Old Jun 12, 2011 | 06:42 PM
jmoser's Avatar
jmoser
sun night decided to finish my mini project--oh yeah right...
replacing the valve cover gasket (down to the valve cover, the bolts are loose but haven't pulled it off yet..)
my breather tube from the valve cover to the air filter down tube (right side of engine= driver's side) is cracked and full of gunk. it was routed to my oil catch can which i had installed per alta instructions...im going to reinstall with drphilgandini's alternate method.
so the airbreather tube will go back to original connection at air filter down tube.
can I just replace the cracked tube with quality fuel hose?
and do I need to use fuel line instead of the alta hose in the new occ setup?
Old Jun 12, 2011 | 06:48 PM
jmoser's Avatar
jmoser
heres the hose routing pic
http://gandini.unm.edu/PGpages/Inter.../Auto/OCCa.jpg
Old Oct 21, 2011 | 07:43 PM
jmoser's Avatar
jmoser
changed OCC back
just an fyi,
in case anyone ever found this thread in a search
I am going to reroute my oil catch can lines to my original configuration, which is detailed here
https://www.northamericanmotoring.com/forums/how-to/88605-r53-drivetrain-oil-catch-can-install-how-to.html
I don't know why, but there was a very fine amount of oil in the sc manifold when I removed my intercooler. It wasn't there before, so I'm going back to the original configuration above..
squawSkiBum
Oct 2, 2015 09:21 AM
The_Kid
Aug 16, 2015 11:13 AM
