Suspension How do I reduce nose lift and dive?
Old Jun 11, 2011 | 06:04 PM
sspreso11's Avatar
sspreso11
2011 MCS, without sport suspension. Sometimes it feels like I am on a rocking horse when doing hard acceleration->braking->then accelerating. I figure I am loosing alot of traction during this too. How best could I address this? Will a set of NM springs be enough? or do I need to think bigger?
Thanks,
John
Old Jun 11, 2011 | 06:43 PM
Raymazing's Avatar
Raymazing
Springs will help drastically. maybe save for some coilovers? I ran a bilstein/h&r shock/spring combo on my r53 and it was great and provided a nice ride. My H&R full coilovers are great but prob out of the real of what you want or need...
Old Jun 11, 2011 | 08:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
A set of NM lowering springs will dramaticly reduce the suspension roll. If you end up doing springs get an Hsport rear swaybar it will be easy to install at the same time and improve the handling even more. The stock springs are just really soft.
Old Jun 12, 2011 | 06:33 PM
scottab36's Avatar
scottab36
PowerFlex USA front control arm bushings along with a set of Bilstein HDs will do the trick. You can lower it if you want but that's not required.
Old Jun 21, 2011 | 02:15 PM
sspreso11's Avatar
sspreso11
Will the suggested setups also help with the jumping around on rough roads? Or is that more so tires causing the issue?
Old Jun 21, 2011 | 06:09 PM
scottab36's Avatar
scottab36
The Bilstein HDs IMHO are the king at smoothing out rough roads. They have a unique valve system that allows them to absorb bumps and rough roads but then not compress under slow compressions like cornering and braking.
I am running the HD Bilsteins with the JCW Sport Suspension springs and I love the ride and the handling.
Old Jun 21, 2011 | 09:29 PM
bluefox280's Avatar
bluefox280
Are you still on the OEM run-flat tires? If so, that's contributing to the "rock-skip" effect.
Strap on a non-run-flat tire that allows some sidewall flex and it'll considerable increase proper traction and response.
- Erik
Old Jun 22, 2011 | 08:37 AM
sspreso11's Avatar
sspreso11
Yup still OEM. The rock skip thing can be scary at 70mph.
Old Jun 23, 2011 | 03:09 AM
etalj's Avatar
etalj
+1
great advice
USNAE2
16
Jun 17, 2022 07:17 AM
M7Speed
Jul 10, 2018 09:26 AM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
