Belt tensioner DIY
Old Jun 11, 2011 | 01:05 PM
windman's Avatar
windman
Belt tensioner DIY
I just broke the belt tensioner tab in the middle trying to put on a new belt. So it looks like I need to replace the whole thing. Do I have to jack up the engine to be able to put on the belt tensioner? I wasnt sure if i would have to go thru all that again or if I could get to everything with out doing all that. Also if anyone know a good DIY thread for that I would appreciate that as well. Thanks
Old Jun 11, 2011 | 01:11 PM
JAB 67's Avatar
JAB 67
I replaced mine without jacking up the engine. I removed the passenger side wheel and inner wheel well liner, however. Its somewhat of a Chinese puzzle to get it out and the new one in, but it can be done.
Old Jun 11, 2011 | 01:29 PM
windman's Avatar
windman
If mine is broken but i do have the alta stop on it do i have to replace the Belt tensioner?
Old Jun 11, 2011 | 05:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you mean the tab in the middle of the spring you don't HAVE to replace the tensioner. The tensioner will work fine still, you just will need to people to change the belt since you can't lock down the tensioner now. We've seen this several times and unless a customer wants a new tensioner we just use two guys to change the belt.
Old Jun 11, 2011 | 07:50 PM
windman's Avatar
windman
Great!!!! I will try that in the morning.
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
M7Speed
Oct 1, 2015 07:05 AM
eliseo1981
Sep 30, 2015 07:57 PM
daviday
Sep 25, 2015 01:31 AM
