Suspension Replacing front sway bar bushings???
Old Jun 11, 2011 | 10:43 AM
drftobin's Avatar
drftobin
Is there any tricks out there to replacing the front sway bar bushings or does the sub frame need to come down??? And if I do need to lower the sub frame is there any thing else I should do why its down???
Old Jun 13, 2011 | 06:56 AM
MiniCooperS43's Avatar
MiniCooperS43
You don't actually have to lower the subframe out of the car. If you just lower the back of it 6 inches or so you'll be able to get a wrench on the 2 bolts on each side holding the sway bushings/Lower control arm bushings down. Since the bolts will be out you might as well replace the lower control arm bushings if you haven't already.
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
