R60 Bad Thermostat, MPG avg indicator
Old Jun 10, 2011 | 05:17 PM
mrod79's Avatar
mrod79
About 2 weeks ago, I got a yellow engine light (manual mentions not having full engine power).
I took my CM in, turns out the thermostat was bad. It took a day to get the part in and a half day to fix. So I was without my CM for 2 days .
Since I've had it back, my average MPG indicator has been at 24.4 and has not moved at all. Before I took it in, I was getting 25.5 to 25.6. It would fluctuate between the two and has never gone below 25.5.
Has anyone with heard anything about this?
Old Jun 21, 2011 | 07:19 PM
doug_all4's Avatar
doug_all4
Had the thermostat done twice now, but no negative impact on gas mileage or the indicator.
Old Jun 22, 2011 | 05:26 AM
Koopah's Avatar
Koopah
Originally Posted by mrod79
{snip}...my average MPG indicator has been at 24.4 and has not moved at all...{snip}
Try zeroing it out along with your average speed. At least that way, you can tell if it is working.
Old Jun 22, 2011 | 06:17 AM
rabbitransit's Avatar
rabbitransit
This car should have a temp gauge.
Did it fail open or closed ?
Did you overheat?
As for MPG indicator, I assume you already reset the average speed and MPG history...right.
Old Jun 22, 2011 | 06:39 AM
John Richard's Avatar
John Richard
Did you accidentally push the SPORT button while using a cup holder? Otherwise, I cannot see that the two issues could be related.
Rohdeandschwarz
May 16, 2019 08:59 AM
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
kjd186
Sep 9, 2015 10:02 AM
