R60 R60 Rear view mirror with homelink buttons
Old Jun 10, 2011 | 02:24 PM
bigchrisz's Avatar
bigchrisz
Is there anyway to add the rear view mirror with the homelink buttons to a Countryman that didn't come with that option?
Does anyone know?
Old Jun 10, 2011 | 02:50 PM
Mojito's Avatar
Mojito
I'm interested in the answer too
Old Jun 10, 2011 | 05:09 PM
dlpruk's Avatar
dlpruk
I tried to order my All4D with this mirror as I found it so useful on my old Clubman but my dealer said it can't be done. But ...
Old Jun 10, 2011 | 06:03 PM
mavic1010's Avatar
mavic1010
I believe its the same mirror as on the R56 and R55. It's not that hard. All you need to do is find a power source and tap into it. If you get the auto dimming its too much work to do the non-auto dim when in reverse, so if you can live with that, its an easy mod. My dealership said it couldn't be done either on the R56....little did they know.
Old Jun 11, 2011 | 07:11 AM
AlfaDude1's Avatar
AlfaDude1
Homelink
I have the homelink on the mirror. My recommendation is to clip a small remote to the visor and don't give it a second thought. The buttons on the mirror are not in a great place and you have to be careful not to move the mirror every time you use them. Just my opinion...
Old Jun 11, 2011 | 07:38 AM
mjgood's Avatar
mjgood
My '05 MCS was pre wired and was real easy to add the mirror, I was going to put that mirror in my CM, but the car isn't pre wired for it....
All I wanted was the garage door opener, my rear window is tinted pretty dark and the auto dim really isn't a concern...
I don't have a sunroof which left an open switch position... I have a two-door garage opener that I took apart and put inside where the motion sensor for the alarm would have gone (I don't have an alarm).
I put a DPDT momentary switch where the sunroof switch would go and wired it to the garage door opener internals, I also put the LED from the opener near the switch.
When I get home in a week I will take photos and make a write up if anyone is interested... I matched the switch pretty close to the existing switches, the whole setup looks almost like it would have come that way from the factory and it controls two garage doors..
Old Jun 11, 2011 | 11:12 AM
j_vincent's Avatar
j_vincent
Very interested.
John
Old Jun 16, 2011 | 12:46 PM
mjgood's Avatar
mjgood
Here is the DIY as promised....
Youtube of the switch in operation...
http://youtu.be/V4xR1_8ydlY
PDF of the instructions...
https://files.me.com/mjgood/kmsy0j
the switch I use will operate two doors, I push the switch forward for one door and backwards for the other door...
Old Jun 16, 2011 | 01:07 PM
j_vincent's Avatar
j_vincent
Wow! Thanks for the very complete instructions. I will be doing this mod. Looks great. Very professional.
John
Old Jun 18, 2011 | 09:42 AM
jwedding's Avatar
jwedding
I've been told that the Homelink mirror will eventually be an official accessory like it is for the other models, it just hasn't been released yet due to the newness of the CM. We'll see....
Old Jun 19, 2011 | 01:01 PM
jonbettie's Avatar
jonbettie
Has anyone had any issues getting the garage door buttons to program? I've tried multiple times to no avail. Would very much appreciate any tips or tricks.
Old Jun 19, 2011 | 02:14 PM
TPBC's Avatar
TPBC
Try resetting the mirror first. Hold the two outer buttons down for 30 seconds ( it seemed more like a minute LOL)
If you have a garage opener with the rolling code you need to push the learn/reprogram button on the back of the garage door motor (it should flash). It would be better if you had another person to help you. I did it by myself and kept missing the 30 second window to make it back to the car in time to engage the program sequence on the mirror. I'm sure it was pretty funny watching me run back and forth a few times. I went through the same thing with our old E93. It must be a BMW thing. It wasn't that difficult with our Lexus. I hope this helps. Good luck.
Old Jun 19, 2011 | 07:04 PM
rewdpost's Avatar
rewdpost
It also may help to know that if you have a rolling code you may need to program the mirror up to 3 times after pushing the "learning" button on the garage opener itself before you are synchronized
Old Jun 19, 2011 | 08:18 PM
bradrulz's Avatar
bradrulz
Anyone ever consider or have mounted a garage door opener in the bottom button area where the sport button and window lock buttons are? Quite a few blanks there if you don't get some of the other options. Was thinking this would be a good place to mount and could be a push button.
Old Jun 19, 2011 | 09:09 PM
Mojito's Avatar
Mojito
Another aftermarket option
http://www.f2ptechnologies.com/
Old Jun 20, 2011 | 06:21 AM
mjgood's Avatar
mjgood
There might me too much blocking the signal from the transmitter, transmitters are very low power, my garage doors are metal and add to block the signal. So far being mounted in the overhead panel it has been working well...
Old Jun 20, 2011 | 01:48 PM
jwedding's Avatar
jwedding
Anyone used one of these? Know what's involved with the wiring? Simple enough, and WAY cheaper than a 300$ mirror to solve the problem.
Old Apr 13, 2012 | 06:31 PM
Mosborn78108's Avatar
Mosborn78108
Talking
Does anyone know?
I spoke to our Mini Dealer as mine didn't come with anything and there is no Home Link mirror after market yet developed for us. In looking at the cost of the R-56 ($650?), I'm not sure its cost effective.
One option I'm looking at the the ON-Star mirror sold by Best Buy. I believe it includes home link.
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
caiken
Aug 27, 2015 06:55 AM
Bennyboy
Aug 18, 2015 07:28 AM
dyeLucky
Aug 7, 2015 07:10 AM
