AC issue
Old Jun 7, 2011 | 04:11 PM
Thomas.Wright's Avatar
Thomas.Wright
AC issue
Is there a spot online for AC analysis?
R53, 2003 MCS
My AC is out just in time for 90+ degree weather. The refrigerant charge is fine, blower fan is fine... so... something electrical? I'm not sure what other components are in the air conditioning system.
Old Jun 7, 2011 | 05:31 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is the A/C compressor working ?
Old Jun 8, 2011 | 07:02 AM
Thomas.Wright
That's what I'm looking for... analysis. Like, what to check and in what order.
I'm assuming/hoping there might be a website out there for this, but I don't know where.
How do I tell if the compressor is good?
Old Jun 15, 2011 | 12:56 PM
Thomas.Wright
BUMP
How can I tell if the compressor is working?
Old Jun 16, 2011 | 06:05 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Just turn it on and look at the compressor. You should be able to clearly see the difference when the compressor clutch engages.
Unfortunately the clutch is not available separately from the $500 compressor.
Rich
Old Jun 16, 2011 | 06:28 AM
Thomas.Wright
OK, please pretend I'm dumb about this... (Because I am)
Where is the compressor?
What part of it is the clutch?
If doesn't engage, how do I know? (As I don't know what it looks like when it works properly)
Old Jun 16, 2011 | 07:28 AM
ZippyNH's Avatar
ZippyNH
You need a high and low side pressure guage to tell if it is acually working....that and the fact if there is refrigant in the system, it is sealed, and you need a vacume pump to evacute the system, and then change the dryer if you open it up before refilling it...not complicated, but you DO need some tools and experance to do it right....
if you cannot identify the compressor....perhaps you need to go to a shop.
Do not add refergant...too much coolant will make the system stop working or burst a line....just like it will stop with too little. Same for the special oil that is mixed with the refergant....other compotents are the two radiator looking thinggs...condonsors...and a expansion valve or oriface, and a few pressure switches....it is abasic car ac system...no computer involved.
Casrio
Apr 20, 2021 01:52 AM
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
Mini Koopa
R55 :: Clubman Talk (2008+)
Sep 8, 2015 02:58 PM
tylewis
Sep 6, 2015 01:07 PM
