Wheel Hub/Speed Sensor Question
This question goes to those who have replaced the new style hub where the speed sensor counts the rollers in the bearing. I took the front hub off, the speed sensor out, and there is a thin metal ring that also goes on the back of the hub. I do not remember the order I took them out. When reinstalling does the speed sensor go in between the ring and the hub, or does the ring go in between the sensor and the hub. I damaged this ring with the sensor when I was removing things so I believe that the sensor sits in between the two. If anyone knows for sure the order these things go in that would be greatly appreciated, and even better yet does anyone know where I can find a replacement for that ring?
thebordella
Aug 31, 2015 01:37 PM
