Drivetrain MC R53 Turbo
Old May 31, 2011 | 06:23 AM
Villa8525's Avatar
Villa8525
MC R53 Turbo
Where can i find an intake manifold?
Old May 31, 2011 | 06:34 AM
ZippyNH's Avatar
ZippyNH
If you are building a turbo r53, pretty safe to say build it..(any turbo on a r53 is custom, a should vary, based up the selected turbo, location....etc).
Lots of hard work ahead of you, like a stand alone engine computer...good luck!!
Old May 31, 2011 | 07:23 AM
BlwnAway's Avatar
BlwnAway
You might want to try contacting someone @ ABF, they might be able to help.
http://www.abftechdivision.com/
Old May 31, 2011 | 09:04 AM
Villa8525's Avatar
Villa8525
Im already installing a halltech computer for my SC but were planning to make it turbo so im trying to get everything before doing it?
Villa8525's Avatar
Villa8525
Can i use the stock manifold?
Old May 31, 2011 | 10:51 AM
KC Jr 54's Avatar
KC Jr 54
There are a large amount of people using the Stock manifold w/ no issues.
Zippy, you dont need a different comp when running a turbo set-up. A lot of tuners use the stock MINI ECU for tuning the car. Every thread you post in, you give false info, please stop.
Old May 31, 2011 | 07:28 PM
ZippyNH's Avatar
ZippyNH
I didn't.mean to post anything misleading...
early on folks tried to run r53 with turbo's....but the boost levels (some with a turbo, zero with sc) at idle caused issues....leading to twincharging as a way to continue using the stock computer.
granted, mini tuning has come a long way since then...tuners now havemuch more experance with more highly customized set-ups...I guess a bit of my info/knowledge is dated. Sorry again.
Old May 31, 2011 | 07:39 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Why not have a FAB shop build one? Some longer runners and a more evenly distributed plennum would do wonders for the tritec if you ask me, and with a front mount I/C there is plenty of space!
And +1 for the STOCK ECU, do a good search for the best option.
Old Jun 1, 2011 | 08:11 AM
Villa8525's Avatar
Villa8525
Whats the maximum boost that i could go with without harming my engine and make it street fun?????
Old Jun 1, 2011 | 09:09 AM
Villa8525's Avatar
Villa8525
I call FAB Shop and they told me that they dont make manifolds for mini cooper so i think i will go with the factory one if i cant find something better.
Old Jun 1, 2011 | 08:29 PM
BlwnAway's Avatar
BlwnAway
No more than 19 to 20psi on stock pistons & innerds.
No offense but doesn't sound like a true "fab" shop.
Old Jun 1, 2011 | 08:35 PM
DICKS GARAGE R53
The factory MAP sensors are only good to 22psi aswell.
Old Jun 2, 2011 | 05:27 AM
ZippyNH's Avatar
ZippyNH
A "FAB" SHOP is a generaic name for a shop that builds single/or sometimes very low volume custom work....they general build ANYTHING for a price...usually mom+pop local types of places....fab= fabrication.
Old Jun 2, 2011 | 08:04 AM
Mike@Tech Division's Avatar
Mike@Tech Division
We have manifolds designed already that should meet the requirements of most turbos that will work well on a MINI. They have been fully flow tested and designed for maximum power output. Its a very nice piece. I'll take some better shot when I get in the shop. We have turbo manifolds too and pretty much every thing else to turbo a MINI.
Few examples here.
Old Jun 2, 2011 | 09:59 AM
Mike@Tech Division
Here is a better shot. It's a little scratched up, it's been in use for almost 5 years on this car. Its on a daily pushing 300 WHP using a Garrett 2876 and a re-flashed stock ECU. We have tested data to modify this design to support up wards of 750 WHP. It's been lab tested, street tested and track tested. This is by far the best manifold available for turbo R53's.
Old Jun 2, 2011 | 01:15 PM
DICKS GARAGE R53
Mmm, MINI ****!
Old Jun 2, 2011 | 08:14 PM
BlwnAway's Avatar
BlwnAway
Now thats what I call fab work.
The turbo car all others aspire to be:
Originally Posted by Mike@Tech Division
Old Jun 6, 2011 | 06:58 AM
Villa8525's Avatar
Villa8525
Mike, do you have the ups rate for the turbo???
Old Jun 6, 2011 | 07:01 AM
Villa8525's Avatar
Villa8525
I already have the ecu, exhaust manifold, injectors, fuel rail, wastegate, BOV, FMIC, what else do i need??? Turbine its waiting for shipping rates.
Old Jun 8, 2011 | 10:27 AM
Villa8525's Avatar
Villa8525
What are MC R53 equiped with MAF or MAP???
Old Jun 8, 2011 | 12:04 PM
Mike@Tech Division
It has 2 map sensors.
Old Jun 8, 2011 | 12:10 PM
Villa8525's Avatar
Villa8525
Thanks again Mike! I really appreciate the help!! Tell your buddy that the money its wating for him to send the turbo!!!
Old Jun 10, 2011 | 03:15 PM
Villa8525's Avatar
Villa8525
/Users/gjestrada/Desktop/IMG_0029.PNG
they dont have to build the turbo manifold, we found this on ebay UK for $300
Old Jun 10, 2011 | 03:21 PM
Villa8525's Avatar
Villa8525
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1156
Old Jun 10, 2011 | 07:20 PM
Villa8525's Avatar
Villa8525
Im about to buy a intercooler. Will 28x7.5x2.5 be to big? Do i have to make a lot of extra mods to install this?? What would you recomend??
