Low Fuel Pressure
Old May 30, 2011 | 09:37 AM
Gottoon's Avatar
Gottoon
Low Fuel Pressure
I have a cold start issue coupled with very very sluggish acceleration. I received a P0171 code several times.
2006 MCS with DDM CAI ~ 74000 miles
I first replaced the fuel filter because I didn't trust the last few tanks of gas I added to the MINI. For the first few days it ran perfect.
Then it started doing the same thing again.
I checked the fuel pressure and it is only reaching 30PSI and it is dropping back to 0 every time the key is turned off.
I am thinking regulator/damper at the injector rail but I wanted to see if anyone has any other ideas.
Old Jun 13, 2011 | 07:18 AM
Cole9953's Avatar
Cole9953
got the same code on mine this weekend, runs perfect other than giving me a hard start several times a week.
did you ever figure it out with yours?
also where did you check the fuel pressure from?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
theblackfalcon
Oct 11, 2015 09:49 AM
David.R53
Sep 1, 2015 06:49 PM
JamJam43087
Aug 16, 2015 02:02 PM
