Squeaky Clutch Pedal
Old May 26, 2011 | 10:30 AM
el_Zilcho's Avatar
el_Zilcho
My clutch pedal has developed a squeak at the first few inches of travel. Sounds like wet shoes on a tile floor, hence I thought it was my shoes at first, but the it makes the sound when pressing the pedal by hand as well...
Anyone else have this? I found a few r56 threads on this, but most of the threads seemed to be related to the throwout bearing going, not sure if the 2011s use the same clutch parts as previous years, but I don't think this is the problem. The sound really seems to be coming from inside the cabin. It seems past BMWs have had issues with squeaky clutch pedals that are related to the bushings on the clutch fork drying out, this seems to be more likely, I hope...
Might take it in if it doesn't go away in the next few days...
Old May 26, 2011 | 12:29 PM
Miniblue2's Avatar
Miniblue2
My R56 didn't have a squeak but had a little bump at about one third peddle. It was a bit annoying. Country has been fault free (knock on Goodwood) so far.
Bill
Old May 27, 2011 | 06:20 AM
el_Zilcho's Avatar
el_Zilcho
hm. mine is right at the engagement point, so it throws me off a little. You can feel the vibration from whatever is causing it in the pedal, if you are braking at the same time you can feel it in the brake pedal as well.
Old Jun 16, 2011 | 09:41 AM
spaner's Avatar
spaner
yep mine squeaks all the time - i figured I will hit it with some WD40 -
I have sort of got used to it but it bugs my wife (ps who says the CM makes her sick but that might be something to do with me trying to get the car onto its door handles :p)
...Well I assume it is some sort of cable noise but re-reading the post gives me more cause for concern
Old Jun 20, 2011 | 06:05 AM
el_Zilcho's Avatar
el_Zilcho
Yeah you may want to take it in. Greasing mine improved things for maybe a day, but it went right back to squeaking. Dealer had to order some parts, I'll let you know what they end up replacing once they come in.
Old Jul 28, 2011 | 12:45 PM
el_Zilcho's Avatar
el_Zilcho
So after greasing, replacement of the compression spring, and the even the pedal, it is still squeaking. It seems to just be a fitment issue... not sure if I want the dealer messing with it anymore
Old Jul 28, 2011 | 02:05 PM
buddy lee's Avatar
buddy lee
Mine squeaks too, and has since day one. I've chosen to ignore it for now and see if it turns into something...
If it develops some resistance or something along those lines I'll take it in.
Old Jul 28, 2011 | 03:27 PM
el_Zilcho's Avatar
el_Zilcho
Its funny because I never really realized how sticky/stiff mine was until they put in the new pedal and greased it all up. It was great for a few days... well for the drive home from the dealership anyway. It is better than where it started. Tolerable now I suppose
Old Jul 28, 2011 | 03:31 PM
kwd's Avatar
kwd
Mine starting make a squeak noise about a month ago
Old Jul 28, 2011 | 04:15 PM
russmini's Avatar
russmini
My three month old Mini S clutch squeaks too
Old Sep 5, 2011 | 03:09 PM
dez's Avatar
dez
Mine is squeaking now too... Driving me crazy!
Old Sep 6, 2011 | 09:36 PM
shutterspeed's Avatar
shutterspeed
Yep. Same here and it's driving me nuts. It also took me a while to figure out it wasnt my shoes. I plan on mentioning it to the dealer when i find time.
Old Oct 8, 2011 | 09:21 AM
muzak's Avatar
muzak
Has anyone found a permanent fix for this? I've taken it to the dealer and they "fixed" it, but it only lasted a few days. I've tried lubricating myself to no avail. It's definitely just a minor cosmetic annoyance and isn't affecting anything performance/drivability-wise.
Old Oct 9, 2011 | 06:21 AM
psu03bob's Avatar
psu03bob
My clutch pedal was squeaking too and started feeling stiffer, especially when the inside of the car was hot. It got so bad it sounded like an old door and starting out in first and reverse became difficult.
In June they replaced a pin and lubricated the pedal, but that lasted only a few days before it started squeaking again. It didn't get stiff like the frist time so I tolerated it until most of my backordered trim came in.
This week they kept the car overnight for a second opinion and MINI told them to modify a push rod and it is quiet and the pedal operates much more smoothly.
I have only driven home from the dealer, but hopefully this takes care of it.
Old Jan 8, 2013 | 11:27 AM
el_Zilcho's Avatar
el_Zilcho
I had this fixed last winter. They replaced my master cylinder and all is well now. I was waiting to update on this until after summer to ensure it was really fixed. So far so good.
Old Jan 8, 2013 | 12:42 PM
Shoe Coupe's Avatar
Shoe Coupe
mine was squeeing, the dealer replaced the pedal and the problem is gone.
Old Feb 16, 2013 | 07:15 AM
zemina's Avatar
zemina
Mine was not a countryman and I already sold mine a while ago, mine was 2008 R56 S. My clutch pedal was squeaking and developed loud noise when shift 2 -3 gear after 6 months since day one.
2008 - they replaced clutch pedal assembly after 6 months since day one
2009 - they replaced entire clutch assembly
2010 - they replaced clutch pedal assembly again
..... so totally they replaced clutch parts 3 times and sold it 2010.
I still love MINI, wife has 2010 R56 S auto and I am thinking to getting the MINI Countryman once my lease ends up this year November.
Old Mar 24, 2013 | 06:55 PM
jgc_tn's Avatar
jgc_tn
Yea, mine has a squeak.......have them ck it when I go to the Mini store.
Old May 13, 2013 | 07:57 PM
Clin10's Avatar
Clin10
My Becca is in the shop for this issue right now too! Hoping they fix it. I am low on warranty miles too, lol!
Old Jun 27, 2013 | 09:36 AM
Somaj's Avatar
Somaj
Thought I'd throw in a post here. I just bought a 2008 Clubman S and shortly after noticed the squeaking. I brought into the service at the dealer to have something else checked and I mentioned the squeaking. I thought something just needed to be lubed. Turns out they needed to replace the master cylinder. Going to pick it up shortly, hopefully it is resolved.
Old Jul 9, 2013 | 07:44 AM
Somaj's Avatar
Somaj
Forgot to update. Got my car back, no squeak at all now. There is however, a slight bump in the down travel about halfway . Felt the same in a newer 2012 that I test drove so not concerned with that.
Old Dec 19, 2014 | 05:57 AM
jsm001's Avatar
jsm001
Unhappy Mini Countryman 2012 Clutch Pedal Noise
I took my car in for a clutch pedal noise. The squeak seemed to come from inside the cabin. The dealer replaced the throw out bearing and clutch assembly. However, when I picked up the car, I noticed a vibration as the clutch is being lifted in first and reverse. The car has been at the dealership since Tuesday (4 days) and still waiting...
drrigg
May 27, 2022 03:31 AM
scfiveo
Sep 27, 2019 02:27 PM
eliseo1981
Nov 2, 2015 11:24 AM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
