Drivetrain 04 to 05 transmission swap
Old May 25, 2011 | 11:46 AM
hippymini's Avatar
hippymini
my 04 mcS 6 speed broke and it needs replacing.
i was thinking about getting the 05 6 speed.
is it a perfect fit?
Old May 25, 2011 | 11:56 AM
s00perc00per's Avatar
s00perc00per
Yeah its the same, you might want to consider Helix's set of gears too as well as a limited slip (if you dont already have one)
Old May 25, 2011 | 01:31 PM
cmt52663's Avatar
cmt52663
https://www.northamericanmotoring.co...ml#post3292239
Old May 25, 2011 | 03:57 PM
Vollgas's Avatar
Vollgas
The transmissions are interchangeable.
The ratios on the 05 trans. are closer in 1st & 2nd.
LSD is nice to have.
You can get an OBX for $400.00
Unless you are racing, you don't need the C/R trans. gearbox.
Old May 28, 2011 | 09:34 PM
RROUNDU
Like it was said in the other thread, you will lose the cruise control due to the different gearing. And the only gear that will have cruise control will be 3rd. I would definitely recommend an LSD too, it just adds to the handling aspect of the MINI even more.
Old May 31, 2011 | 04:39 AM
CrazyIvan's Avatar
CrazyIvan
Mounts up just fine. And I'll echo the earlier comments throw in an lsd.
QuickCooper
Dec 29, 2016 06:46 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Rainforest_Elf
Sep 15, 2015 12:11 PM
Sc00terbum
Sep 11, 2015 09:07 AM
Manny_cooper
Sep 3, 2015 05:48 AM
