Drivetrain Latest news on CAI's and panel filters for 2011+ S?
Old May 25, 2011 | 10:48 AM
Mo'Phat's Avatar
Mo'Phat
I've been going batty reading through the various intake threads, making decision after decision about the best route to go. Then ultimately get tripped up before committing to buy as many of the vendors don't specifically state the intake or filter will work with the 2011's.
Is there a consensus?
I'm fairly surprised there's not much news on the 2011's just yet.
Any help is appreciated
Old May 25, 2011 | 10:54 AM
Mo'Phat's Avatar
Mo'Phat
PS: Oh yeah...and catch cans, too.
And strut tower anti-mushrooming needs.
And..
Old May 25, 2011 | 01:17 PM
cgaubuchon's Avatar
cgaubuchon
As far as I know.
CAI that will fit:
NM (specific product for 2011)
Alta (On my 2011 right now)
BSH looks like is only one known to be making a OCC for 2011. But there is debate in if a 2011 specific one is needed at all.
Old May 25, 2011 | 03:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes there is a specific NM intake now avail for the 2011, also there is a specific turbo heatsheild for the 2011 from NM too. We've been testing and coming up with all sorts of 2011 parts a lot of them are same, but these are two we have avail now.
Old May 26, 2011 | 01:09 AM
Bubbleboy1008's Avatar
Bubbleboy1008
whats a perferred CAI for a track car?
Old May 26, 2011 | 09:46 AM
Mo'Phat's Avatar
Mo'Phat
Do the aftermarket panel filters from K&N, Alta, etc., still fit the airbox?
Old May 26, 2011 | 09:49 AM
Mo'Phat's Avatar
Mo'Phat
PS, thanks for the information Way and cgaubuchon.
Old May 28, 2011 | 06:50 AM
Bravo Zulu's Avatar
Bravo Zulu
Mini Mania and NM Engineering sites will tell you if the part will fit 2011s specifically. Outmotoring will help if you call them with specific part and he'll do the inquiry. I just bought the Helix FMIC, and NM air charge tube, discharge tube, CAI, and heat shield from Outmotoring for my 2011 MCSa.
Old May 28, 2011 | 07:06 AM
czar's Avatar
czar
The factory stock air box fitted to all N14 and N18 engines, are exactly the same base on the air box, it's just the lids that differ between the engines and models!
So the panel filter for the N14 engined MCS, N14 engined JCW and the N18 engined MCS are the same dimensional size!
Old May 28, 2011 | 08:28 AM
Bravo Zulu's Avatar
Bravo Zulu
Yes, but it's the intake pipe that is different on US cars. Makes getting the NM intake about $200 cheaper.
Old May 28, 2011 | 08:37 AM
czar's Avatar
czar
Why do you want to run an open air filter ?
All your doing is subjecting your intake air, to the under bonnet temperatures! you will be better purchasing a performance flat panel filter for the stock factory air box.
Old May 28, 2011 | 12:05 PM
Sacred Disorder's Avatar
Sacred Disorder
Not entirely true. I am running the ALTA CAI and see about 6 degrees above ambient most of the time. And this is cruising around at about 30-50mph. On the Autobahn at 100+ I see 2-3 above ambient.
Old May 28, 2011 | 02:29 PM
Mo'Phat's Avatar
Mo'Phat
I'm not sold on the open filter. Which is why I started this thread. There was a general consensus on previous years that the panel filter was, indeed, the most efficient filter system with the best gains. Open filters may have increased torque or something, but overall performance suffered. I just wasn't sure if that still held true for the N18 motor.
I'm leaning towards a performance panel filter, just for cost/benefit ratio. I don't much care how it looks under the hood.
Old May 28, 2011 | 09:14 PM
Bravo Zulu's Avatar
Bravo Zulu
Just FYI, but you might want to take a look at this link. This is one of the reasons I ordered the NM CAI, and similarly the Helix FMIC. With boost tube and air charge tube, I should be able to get around 205 to 210 HP.
https://docs.google.com/viewer?url=h...8856b-Dyno.pdf
Old May 28, 2011 | 10:15 PM
Laardilla21's Avatar
Laardilla21
I agree with Sacred.
I have the DDMWorks Street CAI, which is an open intake. I see intake temps running around 5-6 above ambient on the highway. I also have a buddy running the JCW tuning kit, which has the closed JCW box, with a cone filter. His closed box also ran about 5-6 above ambient. Of course, running flat out both usually run about 15-20 above ambient or if you are really pushing it, it can get over 100. My DDM still uses the stock bottom of the intake box, which still uses the fresh air intake tube from the front of the car. I also have the fully open scoop opening insert. We ran all our data with ScanGauge IIs. To each his own, I suppose though. Good luck with your choice!
Old May 29, 2011 | 04:21 AM
slimjimtell's Avatar
slimjimtell
Here are some other CAI that work for 2011
JCW Stage 1, closed box with CONE filter...NO OIL!
Defenders of Speed also works, has a noisy Swooshy sound if you like that
VanisleRyan
26
Sep 15, 2015 06:19 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Aug 12, 2015 01:24 PM
