how to kill a warning lamp??
Old May 18, 2011 | 04:27 PM
thefallingtree's Avatar
thefallingtree
i have the warning lamp on that a bulb is out somewhere on my car...
is it possible to erase it without fixing the problem?
i have an obd2 device that can clear CEL issues, but not this one.
it is the indicator that looks like a bulb with an exclamation point in it...
thanks
Old May 18, 2011 | 07:53 PM
Eric_Rowland's Avatar
Eric_Rowland
Could be your TPMS - Tire Pressure Monitoring System
Have you checked your tire pressure lately?
Old May 18, 2011 | 09:28 PM
markjenn's Avatar
markjenn
What is the issue with just replacing the offending bulb?
-Mark
Old May 18, 2011 | 10:29 PM
ScottRiqui's Avatar
ScottRiqui
Just like the circuitry that monitors the airbags, the system that monitors the bulb health isn't part of the OBD-II system, so you're not going to be able to clear it with any standard OBD scanner.
And even if you could clear the light without fixing the underlying problem, it would just come back on as long as the monitoring circuitry is working properly.
Old May 19, 2011 | 08:34 AM
strobeyprobey's Avatar
strobeyprobey
You can remove the hot and cold bulb checks in the FRM module by using NCS Expert. Head over to the Electrical Modifications section and see my post about closing windows with the FOB or the few other getting started threads.
It is not a trivial setup and it basically requires a dedicated laptop and $100 or so cable.
Old May 19, 2011 | 09:16 AM
DneprDave's Avatar
DneprDave
I just put a little piece of electrical tape over the offending warning light!
Dave
Old May 19, 2011 | 10:22 AM
maxmini's Avatar
maxmini
Dave
You beat me to it. Perhaps a small smiley face decal ?
vulkandino
Oct 31, 2015 08:29 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
krohm
Sep 28, 2015 12:16 PM
rt808
Sep 25, 2015 01:59 PM
