R60 $250 Double Load Floor Pictures
Old May 15, 2011 | 10:57 AM
Sealy's Avatar
Sealy
Thumbs up $250 Double Load Floor Pictures
For those of you who wonder how this works, this might explain. I removed the package shelf to make it clearer.
Attached Thumbnails 0 Double Load Floor Pictures-load-1.jpg   0 Double Load Floor Pictures-load-2.jpg   0 Double Load Floor Pictures-load-3.jpg
Old May 15, 2011 | 10:58 AM
Sealy's Avatar
Sealy
Last two pictures . . .
Attached Thumbnails 0 Double Load Floor Pictures-load-4.jpg   0 Double Load Floor Pictures-load-5.jpg
Old May 15, 2011 | 11:16 AM
KiwiRob's Avatar
KiwiRob
Bugger after looking at your photos there is no way you could retrofit a flat boot floor to mine without gutting the boot, the shape is different, I don't have the tie down hooks, or anywhere you could rest the boot panel. This just makes me angry that MINI are charging 250 USD (a lot more in NOK) for something that sholuld be standard, BMW give you a free floor if you order a 1 series hatch and MINI give you one in a Clubman.
Old May 15, 2011 | 11:53 AM
MINIFIDE's Avatar
MINIFIDE
Thanks Sealy, I've been wondering about this since I ordered it. Looks good, and I'm not stressing about it anymore.
Old May 15, 2011 | 12:46 PM
tippykayak's Avatar
tippykayak
Thanks for taking the pictures, Sealy. The weather sucks here and I didn't feel like taking them of mine.
Old May 15, 2011 | 07:31 PM
johnxyz's Avatar
johnxyz
Can someone explain this double load flat floor thing option - I don't understand what I am looking at in the photos. Thanks
Old May 15, 2011 | 09:21 PM
Mojito's Avatar
Mojito
the last picture shows it the best,you see how there is one panel over the cargo area and another covering the back of the seats?
Without the $250 flat load floor, you'd have one of those to choose what you covered, not both
Old May 16, 2011 | 11:04 AM
Miniblue2's Avatar
Miniblue2
Sealy, is it all one unit or are there two pieces? I'm told it won't retrofit if not ordered from the factory, does that appear correct? Also, what does the boot cover rest on, or is the floor higher that the standard option when everything is folded toward the back?
Thanks,
Bill
Old May 16, 2011 | 01:47 PM
Sealy's Avatar
Sealy
Accessory floor is one piece, hinged in the middle so you can lift up the front for access. Bracket underneath on rear section holds it in place. If you look at the next-to-the-last pic (2nd post) - there are two long supports on the sides (with the female part of the bracket in the middle). Those support on the sides, there are also two shorter supports that you can't see - one on each side in the back (opening side). The front is semi-supported by opposite beveled edges on the floor against the wall of the well. Seems to be well supported all around. The whole thing fits snugly in the opening of the well, with the top side level with the floor that supports the standard equipment floor. There is no difference in appearance with or without, installed or not installed.
I would think that the whole thing could be added. It's independent of the standard floor and only requires four supports to be installed. However, I have no idea what it takes to add the supports.
Old May 16, 2011 | 01:54 PM
DeuceBigelow's Avatar
DeuceBigelow
I could see getting that if you don't have a truck or other vehicle to put large items in.
Old May 16, 2011 | 02:57 PM
manuelpl's Avatar
manuelpl
I think I need one of these now.
Do you have any pics showing without it? IS it basically a big gap in the middle ?
Old May 16, 2011 | 03:41 PM
Miniblue2's Avatar
Miniblue2
Sealy, thanks. I guess my three pieces will work just fine for me, except they don't stow neatly away. Just have to store the extra one in the garage.
We took the dog to Plano, Tx over the weekend and had the boot floor in and the other gizzmoe blocking the seats so the luggage was secure and put the dog bed on the folding piece I made to cover the folded down rear seats. Dog's first trip in the harness and she did well and seemed to like it. Bought from Orvis for $29.99.
Bill
Old May 17, 2011 | 12:03 PM
coldnorth's Avatar
coldnorth
We were about to order a car but found one very close that was already in production. It came with the flat load floor as the only option not requested. Now that I see it I am happy. We also carry a dog around and this will be very useful. I plan on getting a pet net (http://www.thepetnetshop.com/) and some type of cargo liner. I would like a poochstyle liner but I am worried about the dog jumping to the front even with the raised center and the cost is high.
With this option I see no point in a bench seat unless you really need to squeeze a 3rd person in the back for short trips. The bucket seats are more comfortable.
Thanks for posting the pictures!
CN
Old May 17, 2011 | 12:43 PM
Sealy's Avatar
Sealy
Originally Posted by coldnorth
I plan on getting a pet net . . .
I'm looking for a net like this for my terriers. I'd like to find one with stainless net cables and maybe an electrical connection.
Old May 18, 2011 | 07:29 PM
Karrock's Avatar
Karrock
On another note, your fourth pic reminded me -- I wish the jack wasn't so friggin huge! And why didn't they make it fit under the passenger seat like it did in my RDX?
Old May 19, 2011 | 04:12 AM
Sealy's Avatar
Sealy
It's not a Acura, it's a MINI. And it's a friggin huge Countryman, so it needs a friggin huge jack.
Sealy - Who's not about to give up his sub woofer space to move the jack.
Old May 19, 2011 | 04:46 AM
vrmoreno3's Avatar
vrmoreno3
The only thing I don't like about the flat load floor is the seats don't lie flat.
Old May 19, 2011 | 04:59 AM
Miniblue2's Avatar
Miniblue2
A couple of hooks, a piece of 3/4" webbing and a fastex buckle and you can have a flat floor.
There are loops on either side of the rear seats covered with a plastic cap which pops off with a flat blade screw driver. Hook onto these and push down on the seats and tighten up on the buckle. The seat wings compress quite a bit and the seats lay essentially flat. Run the strap over the head rest rods. I have done this many times and for weeks at a time. The seat wings haven't suffered and I have the beige leather.
Bill
Old May 19, 2011 | 05:32 AM
vrmoreno3's Avatar
vrmoreno3
Awesome, I will give that a try. Would love to be able to get my road bike inside without laying on its side.
Old May 19, 2011 | 10:01 AM
ghamma's Avatar
ghamma
A couple of hooks, a piece of 3/4" webbing and a fastex buckle and you can have a flat floor...
+1
Old May 19, 2011 | 06:29 PM
mini_z's Avatar
mini_z
The first picture of the op's is the one we get in the CM. Guess the "double load floor " means u get two of these. The second fits below the first.
Mine is fine as is. I do carry lots of tools.
Old May 22, 2011 | 11:46 AM
mjgood's Avatar
mjgood
I really like the flat load floor, since I already have my CM, I decided to make my own....
3/4" particle board, vinyl backed carpet and 3M spray adhesive...
Attached Thumbnails 0 Double Load Floor Pictures-img_1406.jpg   0 Double Load Floor Pictures-img_1407.jpg
Old May 22, 2011 | 02:44 PM
bradrulz's Avatar
bradrulz
Did you use a piano hinge in center? Also where did you find the carpet? Looks like almost a perfect match. Wouldn't mind making this for mine that I just picked up yesterday.
Old May 22, 2011 | 02:47 PM
Sealy's Avatar
Sealy
Looks good - - - but how does it work with the standard load floor?
Old May 22, 2011 | 03:43 PM
mjgood's Avatar
mjgood
I originally put a piano hinge but ended up taking it out, it wouldn't open all the way.. I just used the carpet as the hinge... the hinged part on the factory one appears to be that way.
I just studied how the factory one was made and duplicated it the best I could.
I used the factory floor as a template for mine so it fits in the same recess.. I won't be folding the factory part backwards, only forwards when I fold the seats down.
I got the carpet from partsexpress.com, it comes in black, dark grey and grey. my car has both dark grey and black colors, I decided to use black.
Make sure to use the vinyl backed carpet.
