CM rear view mirror vibration
Old May 11, 2011 | 07:53 PM
old81's Avatar
old81
M6
Anyone noticed the rear view mirror vibration, pretty constant at 40mph +. This is the mirror installed with the Convenience PKG.
Makes the image blurry and comes and goes.
I use the door mirrors more because it is a pain.
Who else has noted this issue?
Don
Old May 12, 2011 | 02:49 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
My R53. But only when I pin it on the highway it can vibrate some, reminds me of looking at cars in the rear view mirror while driving a Grand National Stock car....
Old May 12, 2011 | 06:43 AM
oog's Avatar
oog
yeah mine does it too... it has not stopped me from seeing cars behind so maybe yours is worse. hasnt bugged me enough to try to remedy.
Old May 12, 2011 | 10:58 AM
Miniblue2's Avatar
Miniblue2
So far, 4200 miles, mine is rock solid with no vibration. Are you sure the tires are balanced and round. That would explain the vibration picked up in the mirrio but too little to feel in the steering wheel.
Old May 13, 2011 | 11:32 AM
old81's Avatar
old81
M6
Have not checked the balance and roundness, it will be at the dealer next Wed. I will mention that when I drop it off for an out of cycle oil change.
Around 3K on the CM, wife's daily driver, so it bugs me when I get to take a drive.
You can hold the mirror with your hand and it stops. We shall see.
Remember this is on the New Countryman any model, ours is an ALL4.
Anyone else?
Old May 13, 2011 | 12:27 PM
oog's Avatar
oog
For whatever its worth, I doubt its a tire in the round issue. Can be going fast and have it be still, but if I hit a bump or a rough patch of road its when it starts vibrating. Not any particular speed either. I think simplest answer is probably the right one: the grip on the mirror just isnt that tight...
Old May 19, 2011 | 06:14 PM
old81's Avatar
old81
M6
MINI of Loveland confirmed the mirror shakes and blurrs on our CM.
They confirmed on a CM they had in staging did the same thing, the submitted an engineering puma to see if it will be fixed or if MINI will bother.
Don
Old May 25, 2011 | 05:43 AM
days-like-this's Avatar
days-like-this
Yep mine drives me nuts and has since Day 1. Took it in to dealer and they couldn't fix it so ordered me a new one. I need to get back in for the new install.
Old Jan 12, 2013 | 01:36 PM
Tabintab's Avatar
Tabintab
any vibration in the steering wheel, or through the clutch pedal when u partially depress it?
Old Jan 12, 2013 | 03:01 PM
bmwr606's Avatar
bmwr606
my cms all4 does not have any vibration in the mirror
neither does my dad's cms all4
both of us have the "standard" manual dip mirror, neither has the Convenience PKG
mine is a manual, dad's is an automatic
scott
Old Jan 12, 2013 | 03:58 PM
Paconyc's Avatar
Paconyc
+1 - Mine drives me crazy as well. At times the car can be so quiet....and then all of sudden that mirror starts rattling. It's embarassing when I have someone in the car - makes the car sound like it's not screwed together very well.
Old Jan 15, 2013 | 02:35 PM
Mr_Bueno's Avatar
Mr_Bueno
No vibrations at all with mine at any speed that I've ever noticed. All4 manual. I have the standard mirror with a Union Jack on it. I don't know if that matters. I also have the sensor below it for the wipers... Maybe that stabilized it some more....
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
caiken
Aug 27, 2015 06:55 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
dyeLucky
Aug 7, 2015 07:10 AM
