dreadful experience uphill - stall, e-brake, 3rd gear start
Old May 8, 2011 | 10:46 AM
remotecontrol's Avatar
remotecontrol
wow while i was driving in 1st gear up a very very very steep grade tonight, the rpm got lower and lower...
so i stepped on da gas and it stalled... i had no choice to stop the car... sweat all over my head and the e-brake couldnt grip da car after 5 clicks...
i got panic and i guess i shifted to 3rd gear and released da clutch and rpm up to 5,000 for a second... i smell heavy burning smell afterwards... still able to drive but the burning smell still here after 4 hours....
any damage i have done?
cheers,
r
Old May 8, 2011 | 12:27 PM
HRM's Avatar
HRM
Sounds like you were actually in 3rd when the "event" first occured and you just put it back in third.
Frying the clutch isn't recommended, but with a bit of luck, you will be fine. Just don't make a habit of it.
Don't panic when things go bad. If someone is behind you, ignore them, if they honk put it in reverse (that usually shuts them up...lol...wife did that twice the first week she had her mini, totally by accident, but boy o boy, were they patient after that) Stay off that hill forever.
Old May 8, 2011 | 09:34 PM
remotecontrol
hey cheers mate~
well me quite sure i was in 1st since i started the car with it... well 2 pax in da car with air con on.. just feel lack of power and rpm down... should i just hard press on the gas next time?
btw i have a 40K mile 2008 nonS cab.
Old May 8, 2011 | 11:31 PM
markjenn's Avatar
markjenn
Well, press as hard as you need to to keep going up the hill. The key thing here is not to let the RPMs get too low - 1st gear is not low enough to go up a steep hill at a very slow pace without clutch slipping. So you have to keep your speed up enough that the engine is revving high enough to make sufficient power to keep going. If the engine starts to bog, you're toast.
What you did is very hard on the clutch, but these things can take a fair amount of abuse. You probably shaved a few thousand miles off its life. The smell should go away. If the clutch is making bad noises or shuddering, you may have a new clutch in your future.
- Mark
Old May 9, 2011 | 08:29 AM
kazlot's Avatar
kazlot
It's a very good idea to turn off the A/C in a situation like you describe.
Hope this helps...
Old May 9, 2011 | 09:19 AM
remotecontrol
YAP! definitely. learnt a lesson... especially with a new met girl......... embarassing moment...
Bublik
Feb 18, 2023 11:09 AM
Markbett
Jul 3, 2016 04:28 PM
maestro39
Oct 27, 2015 02:38 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Aug 12, 2015 01:24 PM
