Knock sensor
Old May 8, 2011 | 08:11 AM
jaydeestude's Avatar
jaydeestude
Knock sensor
I have a 2005 Cooper Convertible with an occasional "service engine" light. Had it read at MOTD and is a bad knock sensor. Where is the knock sensor located on this engine? A quick look at it didn't reveal the location. I can get a new sensor and see pictures of it, a sensor that fastens under a bolt on the engine and a lead that plugs into a connector but I don't see it on the car. Anybody know?
Old May 8, 2011 | 08:37 AM
Revolution Mini Works's Avatar
item 6
http://realoem.com/bmw/showparts.do?...82&hg=11&fg=10
Old May 8, 2011 | 08:47 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
On your car its located on the front of the engine behind the intake manifold, you'll have to remove the intake to replace it. The connector is on right by the fuel injector rail. If you need the sensor let us know we keep them in stock.
Old May 8, 2011 | 11:47 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The problem lies with the length of the knock sensor bolt. It's a tad long ....seems longer than it has to be. Before it is even backed out all the way it will hit the back side of the intake manifold....
If careful, you can just loosen the intake manifold enough to snake the bolt out the remaining few threads left....problem is when resetting the intake manifold you "should" use a new intake manifold gasket....your call.
But, before doing anything, I would just make sure you have a proper connection to it. They are not known to be an issue for our cars. Could be the plug.
Old May 8, 2011 | 07:59 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by -=gRay rAvEn=-
...But, before doing anything, I would just make sure you have a proper connection to it. They are not known to be an issue for our cars. Could be the plug.
Artoo (125,000 miles) throws an occasional knock sensor code. Always when on the highway at steady speed. And sometimes with months in between. The code always clears itself. I always use Shell V-Power. And otherwise it runs perfectly.
I bought a new knock sensor and will put it in when I am next in there. But since it happens only occasionally and always when at highway speeds and steady, I am thinking that it could possibly be a leaky injector. Any other ideas are welcome.
Rich
Old May 9, 2011 | 05:17 AM
-=gRaY rAvEn=-
Moderator
Could be.
Or maybe they just need a new set of O-rings.
I swapped out orig. injectors at 80K miles for JCW's. The old ones looked like they had been at the bottom of Davey Jones Locker for two years.... Rusty as hell.
At that time, the original O-rings were hard and brittle so they would have been in need of replacing soon anyways.
Old May 9, 2011 | 07:30 PM
Rich.Wolfson
Could be...Or maybe they just need a new set of O-rings.
Hummmm. Should I have the injectors tested when I take them out to replace the O-Rings? I'll ask the local Diesel shop if they can test our injectors.
///Rich
Old May 19, 2011 | 05:58 PM
bettehead's Avatar
bettehead
Mine was replaced on my 09 MCS a few months ago. Same story: about 5 min into driving (whether warmed up or not) the CEL would go on for 20 seconds, then go off. *shrug* Seems okay since the fix. *fingers crossed!*
riff42
Sep 22, 2015 03:07 PM
sempaipaul
Sep 18, 2015 03:05 PM
tylewis
Sep 6, 2015 01:07 PM
MasterShaftner
Sep 4, 2015 03:52 PM
