Navigation & Audio Noise through speakers with car off
Old May 5, 2011 | 09:05 PM
Matty33's Avatar
Matty33
So is this a normal thing; with the car off if I open the door or when I shut the car off the speakers will emit a sort of white noise for about 10-15 seconds then it stops. Radio is off as is everything else I'm aware of, it's not a problem just wondering if that's normal or what. Definitely coming out of the speakers, not engine noise...I did put my ear right to each speaker and can hear it out of them all. Only the 2nd day with the car so I could be missing something, would not be surprised.
Old May 6, 2011 | 08:22 AM
strobeyprobey's Avatar
strobeyprobey
Not normal! Take it back to the dealer, there is something wrong.
Old May 6, 2011 | 08:47 AM
blacter's Avatar
blacter
Noticed the same thing, Rubicon. Picked up my car on Wednesday.
Old May 6, 2011 | 08:55 AM
Matty33's Avatar
Matty33
Very odd, I contacted the dealer and they aren't sure either so I'm going to try and stop by their service department and see what they say.
Old May 6, 2011 | 09:09 AM
blacter's Avatar
blacter
Keep us posted, please. My dealer is 3 hours away, so can't do a "stop-by."
Old May 6, 2011 | 09:59 AM
phinzup's Avatar
phinzup
Mine does the same thing...
Old May 6, 2011 | 11:04 AM
Matty33's Avatar
Matty33
Hmmm wonder if it's something with the 2011's then. My dealer is an hour away so it's not a quick drive, questioning if I should even bother now
Old May 6, 2011 | 12:03 PM
MiamiGuitarMan's Avatar
MiamiGuitarMan
I have a 2011 and it doesn't do that. I have the base stereo, in case that matters.
Old May 6, 2011 | 12:23 PM
theunclesam's Avatar
theunclesam
Mine does this as well. Had the car about a month.
Old May 6, 2011 | 08:37 PM
Matty33's Avatar
Matty33
So I did a little more testing and what seems to be happening is that anytime power is triggered for things like the overhead lights or dash lights while the car is off triggers the 'R1' relay in the fuse box under the bonnet. Almost seems like maybe a bad ground for the speaker system, or something like that, which would cause the noise of the passing electrical to pass to the speakers
Going to try and make it to the dealer tomorrow so I'll post their findings. I haven't been able to confirm the speakers make any added noise with the car on and the radio off but I'll check that too.
Old May 7, 2011 | 11:31 AM
Matty33's Avatar
Matty33
Just to update this a bit more, it doesn't seem to happen with the car running, tried it today and couldn't hear it at all but turn it off and right away it starts.
Very odd and I can't make it to the dealer until NEXT weekend so ya'll have to stay tuned
Old May 7, 2011 | 08:12 PM
theunclesam
Let us know. For the record, I have Connected w/HK.
Old May 7, 2011 | 08:24 PM
tvanhouten's Avatar
tvanhouten
Adding to the dog pile... Mine does it too, since I first picked it up months ago. I also have an H/K system, but no connected - 2011 MCS.
Old May 14, 2011 | 03:13 PM
Matty33's Avatar
Matty33
Well the verdict is in...."normal" behavior is what the dealership said. Even after hearing it they weren't sure so we checked out some other new ones and they all do it, apparently the countryman is much more noticable for whatever reason. The tech believes that it's just interference being picked up by the speakers as they are powered with the car off to provide sounds for things like the key being left in etc.
So, it's either really normal or they are all broken
Old May 14, 2011 | 05:58 PM
phinzup's Avatar
phinzup
I actually sat in my car this morning for about 5 minutes and the sound never went away. At least I know it's "normal."
Old May 15, 2011 | 10:44 AM
siriuszero's Avatar
siriuszero
Glad to know I'm not the only one...
I have a 2011 Countryman w/ Connected and the HK system and I get the same thing every time.
Old Jun 27, 2011 | 06:44 AM
Drobinson1692's Avatar
Drobinson1692
correct me if i'm wrong, but i believe that's not thru the speakers. I feel as if i heard that's a fan or something (present on both mini's i've owned)
Old Jun 27, 2011 | 11:58 AM
phinzup's Avatar
phinzup
It's through the speakers. The fan is a separate item you can hear from outside the car. There would be no reason for a fan to be running in my car after it has been sitting in my garage all night.
Old Jun 27, 2011 | 12:22 PM
Walt's Avatar
Walt
Poltergeist
If Carol Anne says "They're here", sell the car fast.
Old Jun 27, 2011 | 04:09 PM
russmini's Avatar
russmini
I hear a noise from my cd player everytime I open the door.
Old Jun 27, 2011 | 05:10 PM
phinzup's Avatar
phinzup
Originally Posted by Walt
Poltergeist
You should have heard my car go ballistic the other day after a hard rain. It started shrieking, playing test tones out of each speaker at random, crackling, popping and altogether acting possessed. I was talking to a friend on the phone and all they could hear me saying was, "x;aogdidfasd BRITISH!!! oasdgfyaoie39 BRITISH!!!" What I was saying was, "Holy crap! My car's gone British on me! It's gone British!"
Then it stopped. Completely. Like no sound from the speakers at all, no matter how high I cranked the volume.
Old Jul 29, 2024 | 08:09 AM
pnw_r56's Avatar
pnw_r56
Just wanted to add my DIY resolution to the pile. 2011 MCS base sound system also had white noise, crackling through the speakers whenever the occupant relay was energized, and alternator / engine whine when running through the speakers.
I disassembled the dash and unplugged all of the radio connectors, connected battery to test, and the sound was gone. I applied dielectric grease to the large harness connector pins and sprayed some connector cleaner on the coax connections. Upon reassembly the sound seems to be resolved. We’ll see if it ever comes back..
Getrieben
Sep 12, 2024 07:03 AM
maestro39
Oct 27, 2015 02:38 PM
Mini'mon
Aug 26, 2015 01:02 PM
OutMotoring
Aug 6, 2015 09:32 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
