Help leak diagnosis pump or ??
Old May 3, 2011 | 04:19 AM
BoostAddict's Avatar
BoostAddict
Hi this is my first post
I have a 06 S with 70K and the check engine light was on and these are the codes I pulled.
P1477 Leakage Diagnostic Pump Reed Switch Did Not Open
P2400 Evaporative Emission System Leak Detection Pump Control Circuit/Open
I was under the car and found the Leakage Diagnostic Pump and checked the hoses and wiring I could find, then tapped on it with a wrench What do you think I should do or check next or do I just replace the pump?
Old May 4, 2011 | 08:27 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've seen a few of these pumps fail, but you need to make sure you have no holes or cracks in any of the lines or charcoal tank.
Old May 5, 2011 | 03:41 AM
BoostAddict
hey thanks for the reply. I will get under there and look again. So if I dont find any cracks or damage on the lines or the tank then the pump needs to be replaced right.
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
dinomaniac
Sep 18, 2018 04:19 AM
PSU 98
Sep 11, 2015 11:20 AM
mimaal
Sep 4, 2015 09:09 AM
