P0300 Random/Multiple Misfires
Old May 2, 2011 | 05:34 PM
jacknk's Avatar
jacknk
I have just finished rebuilding my 08 MCS engine after it destroyed itself because of the tensioner/timing chain problem.
Now that I have it running I am getting the following codes:
P0301 Misfire Cylinder 1
P0302 Misfire Cylinder 2
The engine seems to run OK but I do detect a slight miss at idle. It may have a miss at higher revs but I can't tell.
I have swapped the 1 & 2 cylinder coils and plugs with cylinders 3 & 4 and still get the codes for cylinder 1 and 2. So reasoning would say that eliminates the coils and plugs. I was thinking about swapping 1 & 2 injectors with 3 & 4 to eliminate the injectors. I doubt that is the problem but it is a process of elimination.
If you have had these codes please let me know what the problem was. Thanks.
Old May 6, 2011 | 12:33 PM
MCS9211's Avatar
MCS9211
same exact codes a while back as my head gasket began to fail....replacd under warranty. Now a ring on cylinder 1 destroyed itself and warranty has been denied. looking at about $7800 worth of work and I definitely plan on fighting this case with MINI. 08 Cooper S with only 20,500 miles. MINI made a bad decision on the "new" engine in the R56 and now they need honor their warranty and not look for every little excuse to deny
Old May 6, 2011 | 01:39 PM
jacknk's Avatar
jacknk
When I was swapping injectors I noticed a vacuum hose off below the intake manifold. I think this was where the misfires were coming from.
You can buy a new engine from Mini for around $3500. $7800 seems to be a bit much. I would fight also.
Old May 6, 2011 | 01:45 PM
MCS9211's Avatar
MCS9211
$3500?? They quoted me $11,700 for a brand new crate engine!! Holy crap I gotta get to the bottom of this
Do you happen to know where you got that price from? Brand new engine or rebuilt one? Any info will be great
Also, was your warranty denied also or why did you have to rebuild the engine yourself?
Old May 6, 2011 | 02:17 PM
jacknk's Avatar
jacknk
I bought my 08 MCS at a used car dealership with 89K on the odometer. It would not run so I had to rebuild the engine.
The 3500 is a new crate engine with a 2 year warranty. There is a $500 core charge. Call 800-697-8812 and ask for the parts department. Talk with Dustin or Andy and tell them that Charlie in Decatur said to give them a call about the engine.
Old May 6, 2011 | 07:54 PM
jacknk's Avatar
jacknk
What test have they done to know that a ring is bad on cylinder 1????
Fordgt4
Oct 10, 2015 10:42 AM
randeez
Oct 5, 2015 09:23 AM
dutchhome
Sep 30, 2015 07:17 AM
silence2-38554
Sep 28, 2015 12:19 PM
ShadyCoop
Sep 20, 2015 08:57 AM
