Brake Fluid service light
Old Apr 15, 2011 | 11:30 AM
Mini2na's Avatar
Mini2na
I just picked up a Service needed light. I check in the Check/Info and found it was a Brake Fluid light.
Does this mean a fill or replacement? If it is replacing the fluid, what type should I use for Autocrossing and what tools will I need to use to do it alone? My bet is that I can buy the tools and upgraded fluid for the cost of a dealer visit.
Will I have to replace it again when doing the front brakes in 6K mi?
Old Apr 15, 2011 | 01:06 PM
jcauseyfd's Avatar
jcauseyfd
iirc, it is for a fluid replacement. I think the OBC calculates the brake fluid flush on a two-year cycle.
Should just need a simple brake bleed kit and basic tools. Not sure on a recommendation for type of fluid for autocross though.
Old Apr 15, 2011 | 09:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The computer in the MINI is programmed to tell you to change the brake fluid every two years. That is when you should replace it anyway.
If your going to do AutoX you should get the Motul brake fluid
minimofo
Dec 26, 2015 11:45 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
oldkid6
Aug 11, 2015 08:13 PM
