R56 Question about keyless start up
Old Apr 12, 2011 | 07:36 AM
the matey's Avatar
the matey
Today I started my 07 mcs and then turned it off, pulled the key out then pushed the start button which started the car with out the key. This only works sometimes (only when you start it with the key first) Is this a glitch?
Old Apr 12, 2011 | 10:08 AM
schatzy62's Avatar
schatzy62
I have heard this before and i believe it is just a timing issue. If you catch it with in a few seconds then it can start but more than about 15-20 seconds i doubt it will start for you.
But I could be wrong. I have been before.
Old Apr 12, 2011 | 11:27 AM
strobeyprobey's Avatar
strobeyprobey
It is easy to start the and run the car without the fob! And I am not talking about comfort access FOB either.
Set the fob in the dash holder (don't click in) and press and hold the start button for about 30 seconds. The car will start up and run.
Then you can pull the fob out of the dash. You may get a FOB/CAS yellow warning in the tach display. This is a "secret" backup way to run the car in case the latching mechanism breaks or jams.
Old Apr 12, 2011 | 11:49 AM
AustinS's Avatar
AustinS
I wonder if there is a secret way to start and run the MINI if you have lost your fob?
Old Apr 12, 2011 | 08:22 PM
the matey's Avatar
the matey
Thanks, very interesting guys
Old Apr 13, 2011 | 10:26 AM
robby71's Avatar
robby71
so does the steering lock deactivate with the fob out?
alistaircookie
Oct 8, 2015 10:52 AM
Getrieben
Aug 15, 2015 09:09 PM
Eric Chen
Aug 12, 2015 12:04 PM
ludedude
Aug 10, 2015 07:16 PM
