headlight adjustment
Old Apr 9, 2011 | 11:34 AM
jcarlos914's Avatar
jcarlos914
I've searched and found that the white plastic screw behind the housing is to adjust the light. After hitting a pothole that broke the inside of my light my dealer replaced the whole housing and adjusted the headlight but it is much lower than the other side...
Now after turning that white screw both ways nothing happens at all. Is there some trick that I'm missing..I've used both a screw driver and an allen key and nothing happens. the screw turns but the light doesn't move..Is there something else i can do to raise the light?
Old Apr 9, 2011 | 03:51 PM
dlpruk's Avatar
dlpruk
I've adjusted mine as you describe because my dealer's beam-setter put them so high as to be dangerous TMM. But only a fraction of a turn was very noticeable when I did it so summat's wrong.
I hope your dealer isn't too far away!
Old Apr 9, 2011 | 03:53 PM
dlpruk's Avatar
dlpruk
I've adjusted mine as you describe because my dealer's beam-setter put them so hig as to be dangerous TMM. But only a fraction of a turn was very noticeable when I did it so summat's wrong.
Old Apr 9, 2011 | 03:57 PM
dlpruk's Avatar
dlpruk
How do you delete a duplicate post?
Old Apr 11, 2011 | 03:09 PM
jcarlos914's Avatar
jcarlos914
I guess I'll have to go to the dealer I really wanted to avoid it.
Old Apr 15, 2011 | 06:15 PM
teamrubixcube's Avatar
teamrubixcube
This may sound stupid, but make sure your lights are on when you're doing this. If you have the xenons they are going to auto level as soon as you turn the car on ....you need to level them with them already on and the auto leveling complete. It should be a noticeable with just one full rotation around. It sounds like yours isn't catching or is broken.
Old Feb 4, 2013 | 05:12 AM
alanmcs's Avatar
alanmcs
My headlight was pointing at the ground the other evening. About two weeks ago I hit a pothole, blew two tires and broke a wheel. From reading you post, I guess that is what broke my headlight adjuster. I took out the light assembly and noticed that the post that attaches to the adjuster was broken. I was able to reach in and found that it was a clean break. Broke out the trusty JB Weld and had a go at it. It has only been a day so far, but I am able to adjust the light and it seems to be holding quite well.
Old Feb 4, 2013 | 03:43 PM
maverickjcw's Avatar
maverickjcw
Do you have any photos taken for that white screw? or where it was broken? Becasue I believe I have the same issue happen just yesterday, I hit a pothole as well, and the driversider head light is not aiming right after ..... :(
Old Feb 5, 2013 | 05:32 AM
alanmcs's Avatar
alanmcs
Headlight Adjusting Screw
Here is a link to a previous post that shows the adjusting screw.
https://www.northamericanmotoring.co...ment-screw.jpg
Just take into consideration, that my headlight issue was more than turning the adjusting screw, and I have the halogen headlights, not the self leveling.
Kevdog
Electrical
17
Jun 4, 2016 02:20 PM
Vaderm34
Sep 27, 2015 09:25 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
tylewis
Sep 6, 2015 07:36 PM
Ntety
Sep 2, 2015 08:39 PM
