Suspension Will they rub?
Old Apr 9, 2011 | 10:51 AM
adam_randell's Avatar
adam_randell
Will they rub?
I have AP coilovers, set pretty low. Currently running ZCW Angel wheels which are 7.5j et38 18" with 215/35/18. The tyre is around 5mm from the suspension strut (well, at least the adjuster ring to adjust the ride height).
Getting new wheels which are 8j wide, 17" and et35. i THINK the tyre size is 205/45/17. Meaning 3mm less clearance inside and 9mm more poke outside.
however they are 1" smaller so hoping that will make a difference, as i dont think a 3mm shim is an option as the offset would then be 32. just after your opinions really, picking them up tomorrow so will test fit them then but just wanted a bit of a heads up really.
Old Apr 9, 2011 | 11:20 AM
iwashmycar's Avatar
iwashmycar
sounds like they'll clear pending the tire doesnt have some ridiculous huge rim protector rubber on it
Old Apr 9, 2011 | 11:42 AM
adam_randell
thanks a lot for the reply! as far as i know they dont have a rim protector. really hope they do fit! otherwise will have to raise the coilovers up :(
Old Apr 9, 2011 | 12:01 PM
Creeve's Avatar
Creeve
an offset in the low 30's should be fine. I just test fit 17x8 et30 and everything looked good. I do have a bit of camber helping out though.
Old Apr 9, 2011 | 12:05 PM
adam_randell
nice! thats gonna have stannceee! will test fit them as soon as i get them back tomorrow and post some pics up!
Old Apr 21, 2011 | 03:46 AM
Stryker305's Avatar
Stryker305
If you do start rubbing watch your outside edge of your tires carefully
There is a sharp metal edge to the inside of the plastic wheel arch which is the true wheel well's edge and on bumps or depressions on the road
Will start cutting the tire. The sharp edge sits under the felt son you won't feel it untill it the felt is rubbed out. I have 18x8 with 15 mm spacers in the rear and it's cutting my tire I will have to change the spacers out. Or roll the edges if possible
Do you have any h&r spacers on those they look flush almost poking past or outside the arch?
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
Carwash
Sep 15, 2015 02:02 AM
