R52 Mould smell coming from A/C
Old Apr 2, 2011 | 11:28 AM
taffyc's Avatar
taffyc
Hi There,
I'm noticing a pretty strong mould smell when I turn on the A/C in my 07 S Conv. It is particularly noticeable just after I turn the A/C off but I'm also aware of it just in general when the A/C is on.
Any clues on what could be the source and how to fix? I'm at about 45K miles and still under 4 years - do you think this would be covered by warranty??
Thanks,
TC
Old Apr 2, 2011 | 01:30 PM
ZippyNH's Avatar
ZippyNH
Most auto places sell cleaners areosol or foam you spray into the intake....it will kill the growths on the condensor....the dealer will do the same thing.common issue. Sometimes a plugged ac drain can make it worse. Common to ALL cars of every type in the last decade.
Old Apr 2, 2011 | 04:29 PM
Capt_bj's Avatar
Capt_bj
change your cabin filter
it is probably horrible
an easy 2 minute job . . .
Old Apr 2, 2011 | 04:54 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
yeah, I just chaged mine and it was nasty just after 25K miles....
Old Apr 2, 2011 | 06:17 PM
buzzsaw's Avatar
buzzsaw
Here's a DIY for the filter change. Good luck.
Old Apr 3, 2011 | 09:42 AM
taffyc's Avatar
taffyc
Thanks all - will replace the cabin filter for sure. Question for Zippy:
I'm not sure where the intake is these days? Is it still under the wiper blades or....??
Old Apr 3, 2011 | 10:05 AM
taffyc's Avatar
taffyc
One more question - what is the difference between the microfilter and activated carbon filter types?
Thanks TC
Old Apr 3, 2011 | 10:28 AM
ZippyNH's Avatar
ZippyNH
There are 2 choices...the carbon filter...absorbs odors...and regular white.
On fresh air the intake should be br the wipers....you can hear it with the fan on hi...
ZEP sells fridgee fresh.....there are several products out there....
I bet after a bit of use, it goes away...a filter is a good start ...
the ac freshners/cleaners can help too.
Old Apr 3, 2011 | 01:32 PM
Capt_bj's Avatar
Capt_bj
Thanks TC
as far as I can tell, just the type of paper used . . . oh, and the price!
the auto-a/c comes with the carbon filter while plain a/c gets plain paper but they appear to be of the same size and construction so they are interchangeable...
in theory the carbon is better at absorbing oders but I think frequent changes plays a bigger role.
Old Apr 13, 2011 | 02:57 PM
Mini Mania Info's Avatar
Mini Mania Info
Here is a product that might help.
ken
Getrieben
Sep 12, 2024 07:03 AM
wkp1219
Nov 13, 2015 07:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
Red Raven
Aug 11, 2015 04:48 AM
