D Stock SCCA Solo II G Stock FAQ
Old Jan 15, 2004 | 11:50 PM
BGarfield's Avatar
BGarfield
SCCA Solo II G Stock Class FAQs
- G Stock is where the MINI Cooper S is classed
- It's main competitors are cars such as the Toyota Celica GT, Dodge Neon, Subaru Impreza 2.5RS, BMW E30 318is, etc.
- What modifications are allowed in SCCA Stock class?
Any front sway bar, end links, and bushings may be used.
Any exhaust from behind the catalytic converter and back may be used.
Any spark plugs may be used.
Any spark plug wire may be used, including those with an in-line capacitor.
Any performance coil may be used.
Any wheel that is the same diameter, width and offset (within +/- .25 inch or about 6mm) as a factory wheel. Wheel spacers may be used to meet the offset requirement as long as the spacer is no more than .25 inch thick.
The allowable sizes for the MCS are 16x6.5 offset 48mm and 17x7 offset 48mm.
Any D.O.T. approved tire that fits on the rims stated above may be used. This includes Hoosier A3S03, R3S03, A3S04, and R3S04, Kumho V700s and V710's, Yoko A032R and Rs, and Michelin Pilot Sports. The best tire choices for the MINI Cooper S is the 215/40R16 from Hoosier (as of 1/15/04) with 205's available in both 16's and 17's. Some 225's are available, but are much taller diameters and have fitment problems.
Any air filter may be used, as long as it is the same size and shape of the original. The air filter must fit in the original air box. Running without an air filter is also allowed.
Any shock absorber with no more than two adjustments may be used. The shock must mount in the original location. On shock absorbers with adjustable spring perches, the perches must be welded in place.
- If it does not say I can, can I?
No. The rules are very specific about modifications.
- I have heard about comfort and convenience, what falls into this category?
C&C is to allow you to make modifications to your car that offer no advantage while auto crossing. Some examples of allowable C&C upgrades are-
Aftermarket stereo equipment (this does not allow the removal of the stock radio or speakers)
Driving lights, clear taillights, clear side markers, and alternate gas cap lids.
- Can I retrofit options to my car if it didn't come from the factory?
Yes. The rules state that you must change all the parts that are included with the package, such as the Premium Package. This is where the MINI has an advantage over other cars in stock class. At MINI, almost any option can be ordered separately, therefore allowing it to be added at a later date. Some less fortunate cars require major add-ons to get minor changes.
If you have any questions or corrections to what I have written, please post them here or email me at the address below so that I can update the FAQ.
Thanks,
Brian Garfield
_________________
2002 SCCA Pro Solo H Stock Champion/ STX Cooper S in 2003/G Stock Cooper S in 2004. Moderator: PRO SOLO and G STOCK
garfield@northamericanmotoring.com
Old Sep 6, 2005 | 08:49 AM
Scoobywrx's Avatar
Scoobywrx
Wouldn't this allow JCW parts then that come with the package?
Old Sep 6, 2005 | 10:09 PM
BGarfield's Avatar
BGarfield
Something I missed in the above is that in order for a Package Conversion to be allowed, it has to be the same model year.
So yes, if you had a 2006 Cooper S without a JCW package, you could add the full package to the car and be legal for Stock Class (wherever they place the JCW car).
However, the current (2005 and earlier) JCW package is NOT a factory option, therefore 2005 and earlier cars cannot be converted and still be legal for Stock Class.
Brian
Old Oct 9, 2006 | 06:52 PM
Drillslinger's Avatar
Drillslinger
Just checking to see if I understand this right, I have a JCW Intake on my MCS. Just the intake (but it's an official part). Since it's the whole KIT that is offered from the factory then unless I add the head, s/c, etc. I no longer qualify for this class? Or would I then be bumped to the B-Stock (with the full JCW kit)??
Thx
Old Oct 9, 2006 | 07:55 PM
JustGo4It_'s Avatar
JustGo4It_
Changing the intake would put you in STX even if it is an official part. To be placed in B Stock you would need the whole kit.
Old Oct 9, 2006 | 08:00 PM
Drillslinger
Figures Thanks
Old Oct 9, 2006 | 08:05 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Great information! Thanks, well done.
Old Oct 16, 2006 | 03:09 PM
mitchman's Avatar
mitchman
Really? I've never read anything about allowing a performance coil as a replacement for the factory one. Hmmmmm........
Old Oct 16, 2006 | 03:16 PM
Gromit801's Avatar
Gromit801
I wonder where M7 SRP's come into this.
Old Oct 16, 2006 | 04:32 PM
nygaard's Avatar
nygaard
Not stock legal
Old Oct 16, 2006 | 04:37 PM
Motoring's Avatar
Motoring
The coil is a replaceable ignition wear item like spark plugs and wires.
Old Jan 3, 2007 | 04:02 PM
pigeon's Avatar
pigeon
How do all the ecu changes fit into this picture? Mini has made some many runing changes. I actually had the last(?) one removed and the old program reinstalled because the the car felt as if it were detuned. Why couldn't someone simply install the Shark profile?
So urethane bushings are OK on the sway bar??
Old Jan 3, 2007 | 04:30 PM
Motoring's Avatar
Motoring
Dealer reflashes as part of regular maintenance or TSB's etc are OK
Because that would be cheating...
Yes, front swaybar bushings are unrestricted.
Old Jan 3, 2007 | 04:37 PM
pigeon's Avatar
pigeon
I knew that.........
I knew that reprogramming had to be outside the rules, but had to ask. It seems as natural as changing jets in a carb, timing etc.
Thanks.
Old Apr 11, 2007 | 08:40 PM
graphicjoe's Avatar
graphicjoe
You can change carb jets, but the carbs are difficult to locate on the MINI, very difficult.
cheers,
Joe
Old Jul 24, 2007 | 01:55 PM
wrxdriver's Avatar
wrxdriver
So Im guessing that the lsd that you can order from the dealer is ok for this class?
Old Jul 24, 2007 | 02:23 PM
Motoring's Avatar
Motoring
Yes, because it is a factory option. but you cannot install a quaiffe.
Old May 16, 2010 | 09:28 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For the new 2010-11 season the SCCA and reclassed
The stock Cooper S in all body styles into
D Stock not G Stock.
Old Aug 11, 2010 | 03:46 PM
Wetworth's Avatar
Wetworth
Will Koni FSD dampers push the car out of stock?
Old Aug 11, 2010 | 04:25 PM
mitchman's Avatar
mitchman
No. As long as they are a direct replacement for the factory shocks, they are stock legal. In other words, you need to be able to use all the factory hardware. The same springs, and all associated attachment hardware.
Shocks are a "wear item" and all wear items can be legally replaced per the Stock class rules. (tires, brake pads, air filter, shocks, spark plugs, spark plug wires, coil) Being able to replace the front sway-bar is the only discrepancy in the "wear items" scenario.
Old Aug 11, 2010 | 04:49 PM
Wetworth's Avatar
Wetworth
Excellent, I just wanted to make sure before I spent the $$$
Old Aug 13, 2010 | 08:58 PM
JustGo4It_'s Avatar
JustGo4It_
The Koni Sports would be a better choice due to their adjustability. You want the rear of the car to be as stiff as possible to help the car rotate.
Old Aug 13, 2010 | 09:15 PM
Wetworth's Avatar
Wetworth
I would like to but the MINI's gonna see a lot more time with a car seat in it than track time in about 4 months I guess my priority now is ride comfort, if I can also improve handling its a bonus
Colt45Magnus
Aug 27, 2024 05:03 AM
USA-RET
Nov 9, 2015 07:27 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Sep 4, 2015 09:23 AM
