R55 EBC Redstuff pads. Anybody got em?
I want to buy the correct EBC Redstuff pads for my JCW Clubbie but I can't find the fronts for sale anywhere. Is anyone running these? If so What do you think and where did you get them? Any other options out there in use?
EBC's are not yet available for Gen 2 JCW Mini's
I looked high and low. There is an EBC part number, but two different places checked and reported back they are not actually being shipped so far. I looked over on the English side too, and couldn't find them there either.
I concluded the only gen 2 JCW front pad choices are currently OEM, Carbotech and maybe Hawk. Since then another post said maybe Porterfield's too, but reported some questions on quality.
Rears are easy--they interchange with the S.
Agreed...
if it is a DIY (or you otherwise pay), you might keep the backing shims off the OEM pads. The replacement OEM's will come with them, but at least Carbotech's don't. They may be valuable to you (or others) in the future. They are needed to get the pads to fit into the calipers without a lot of extra play--they wrap around the sides of the pad steel backing plates as you will see. Take a while to pry off carefully--there is some adhesive--but it's possible.
Wear sensor (mounted on the front left/ driver's side caliper only) is the same as S's at the part number level by the way if you have any problem locating that--I did an R56 S to JCW front conversion just last weekend so know that from field experience swapping it over. How I know this other stuff on the pads as well.
I found them on the EBC.com site they are available.
Part # DP31854C Red Stuff $109.00
Good Luck.
Good Luck.
Correction....
They have them here...
Part # DP31854C Front $109.00
Part # DP31931C Rear $81.05
http://www.perfectbrakes.com
Regards,
Claus
Regards,
Claus
**UPDATE**
April, 23, 2011
Hi
Unfortunately, EBC have yet to produce this part number.It is likely to be at least 3 to 6 months before it is available.Part # DP31854C Front Red Stuff
Regards
EBC Brakes Direct Limited
http://www.ebcbrakesdirect.com
Office opening hours Monday to Friday, 9am to 5pm
April, 23, 2011
Hi
Regards
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
