Interior/Exterior Oil Pressure sensor now on the oil filter housing - N18 - temp/pressure sensor?
Old Mar 21, 2011 | 11:03 PM
BChili's Avatar
BChili
Oil Temp Gauge install on 2011 MCS - new sensor position?
Has anyone has explored the possibility of installing a gauge related oil temp/oil pressure sensor near the repositioned oem oil pressure sensor? Looking at the RealOEM site for the N18 motor, the sensor is now on the oil filter housing -
http://www.realoem.com/bmw/showparts...74&hg=11&fg=30
... in that diagram, there apppears to be a possible tapped plug just above the sensor. Anyone had a chance to open that plug to see if a gauge sensor will fit?
Old Oct 10, 2011 | 02:35 PM
Performance Angst's Avatar
Performance Angst
Did you ever find and answer to this ? I'm looking for a good place to install a oil temp sensor.
Old Oct 11, 2011 | 08:53 PM
BChili's Avatar
BChili
No answer and have about decided to just bite the bullet and get an oil pan gasket... Plan is to drill a hole in the oil pan at the first oil change (be at 5K miles, pull the pan and drill it, off the car). Got this from Amazon today - Derale 13010 Universal Drain Plug Kit with 1/8" NPT Plug (http://www.amazon.com/gp/product/B000CJ0626) and will probably use the flat side of the pan on the passenger side... Maybe installing this weekend if I get a gasket...
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
