Suspension R53 air ride suspension by airrex!?
Old Mar 21, 2011 | 11:45 AM
SlyCooperR53's Avatar
SlyCooperR53
i stumbled upon this and i dont know where to buy it im really interested. does anyone know about this?
http://www.airrex.com.tw/xGallery/Ga...%20Stage%20III
Old Mar 21, 2011 | 12:57 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Not sure where you live, but our club's mechanic who specializes in MINI's and BMW's is in the middle of installing a kit into a wide body R53.
You can call them or stop by if your in the area.
www.greasysgarage.com
Old Mar 21, 2011 | 01:08 PM
hefro's Avatar
hefro
Just FYI. Greasy's had to do a rear seat delete to get it to fit into the R53.
Old Mar 21, 2011 | 01:15 PM
SlyCooperR53
grayraven, i live in johnston ri, ive talked to you a couple times over at inskip. ill have to take a ride to greasys some day
Old Mar 21, 2011 | 07:50 PM
luseboy's Avatar
luseboy
http://www.motoringunderground.com/f...ad.php?t=10415
its a clubman, but still a good read on air suspension if you go through it all. its been done to a few r53's, mainly across the pond, but it has been done. as i understand it, it's a pretty tough job. and im not sure about that kit, but i know from reading the thread i linked that for a lot of the systems you will have to remove your rear swaybar due to clearance issues. honestly on the r53 it doesn't seem worth it, considering you can pretty much lay frame with v-maxx c/o's, and 15's...
Old Mar 22, 2011 | 11:09 AM
SlyCooperR53
coilovers are alot cheaper than an air ride system but i have a reason. i live on a really bumpy dirt road and it would be nice to lift it when im driving on it then drop it when i get on the good roads.
Old Mar 22, 2011 | 11:36 AM
luseboy's Avatar
luseboy
well i guess if that's what you want to do. but also be aware that changing the ride height at all seriously affects your alignment. Rally from that thread i posted doesn't drive the car all the way lowered, im not sure air suspension is supposed to be driven on fully lowered. But aside from rubbing issues and scraping issues and having no suspension fully lowered, he also has -6 degrees rear camber . if it's what you want to do, it's what you want to do. But to me it just seems like more of a cruise-mobile thing. I could see doing it on a 1960's chevy impala, just doesnt seem right on a little r53... but to each his own.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Emnotek
Aug 13, 2015 05:47 PM
ki7hy
Aug 12, 2015 07:07 PM
