R50/53 how to adjust the high beam headlight on an R53
Old Mar 20, 2011 | 12:00 PM
skyhawk940's Avatar
skyhawk940
How do you adjust the high beams? I have HID's and the low beams are fine, I have one high beam that's too low. I don't wnat to mess up my low beams by getting on the wrong adjuster.
Skyhawk940
Sandusky, OH
Old Mar 20, 2011 | 12:15 PM
Eric_Rowland's Avatar
Eric_Rowland
AFAIK there is only one set of adjustment screws. Mine were set WAY low when I got it.
Old Mar 20, 2011 | 12:27 PM
skyhawk940's Avatar
skyhawk940
If I adjust the high beam higher, will the low beam auto level at the correct place???
Skyhawk940
Old Mar 20, 2011 | 12:39 PM
J_Westy's Avatar
J_Westy
Skyhawk940
Nope - they adjust together.
I had a similar issue and it turned out that the high-beam bulb itself wasn't seated correctly. There's 3 little tabs that are supposed to hold it in place and one wasn't on correctly... give that a look.
Old Mar 20, 2011 | 02:40 PM
Capt_bj's Avatar
Capt_bj
As J said, If just one beam appears to be aimed wrong on a GEN1 I suggest checking to see if that bulb is seated properly in the socket.
On a GEN1 the high and the low use sep' bulbs and if a bulb isn't sitting correctly in the socket its aim is off for the reflector and it points off into never-never land
I learned this when I changed all 4 of my GEN1 (02-S) bulbs out for SilverStars..... Suddenly one beam points towards outer space .... oops, put it in the slot correctly and then it is fine . . . .
Dec 23, 2015 10:36 AM
cw40342
Oct 27, 2015 12:30 PM
Emnotek
Aug 13, 2015 05:47 PM
