R50/53 Transmission maintenance: Flush or Change?
Old Mar 14, 2011 | 07:14 PM
Checkmate_2006's Avatar
Checkmate_2006
I have a question. I have been reading about the fluid service recommendations for the Aisin. My MINI has 39,300 miles on it now and the fluid has never been changed. I would like to change the fluid and filter for preventive maintenance to ensure the cleanliness of the fluid help keep the transmission running in top condition. When I called for a quote at a few independent shops for transmission service, the cost to change the fluid is about $450 more than flushing the system.
So here is my question: Given the miles on my car, should I flush the transmission fluid and have the filter changed, or is it better to simply bite the bullet and change the fluid and filter?
Thanks!
Old Mar 14, 2011 | 07:32 PM
jump'n'jive's Avatar
jump'n'jive
go buy 6 quarts of mobil one synthetic. do 3 drain and refill in your garage. you will get about 2 to 2.5 quarts out each time you drain. whatever you drain out replace with the exact amount. its a simple process. i've done one drain and refill and can tell a difference in my tranny. cant wait to do another one.
Old Mar 14, 2011 | 07:41 PM
Checkmate_2006
How hard it is to access the drain plug on the transmission? is there a filter as well?
Old Mar 14, 2011 | 07:45 PM
jump'n'jive
the drain plug is the easy part. remove the plastic panel underneath and its right there. the fill plug is the hard part. its a t-55 torx bolt and getting a funnel in there and not leaking atf when refilling is the challenging part. my garage smells like atf
Old Mar 14, 2011 | 11:49 PM
Checkmate_2006
LOL, thanks! So you think this is the best way to go then? How will I know how much fluid I have drained? Is there a canister they make that labels/measures how much fluid has been drained?
Old Mar 15, 2011 | 06:03 AM
jump'n'jive
the drain pan i bought at walmart has markers iindicating quarts. also u can buy a clear container that has measurements on it as well. its really easy to do and highly worth it.
Old Mar 15, 2011 | 09:57 AM
Checkmate_2006
Thanks a lot. I will probably do that and change the oil this weekend after I am finished with Winter Quarter final exams. Is there a filter that should be changed as well for the transmission?
Old Mar 15, 2011 | 11:54 AM
jump'n'jive
from what i have gathered the filter is nothing more then a screen and its not worth the trouble to change the screen. it requires pulling the pan. you will be fine with just doing the fluid.
Old Mar 15, 2011 | 12:17 PM
Checkmate_2006
alrighty, thanks again!
Old Mar 15, 2011 | 05:02 PM
gorillajin's Avatar
gorillajin
Hi,
Our 2006 mini has 26k miles, and I am about to do 30k miles service myself.
I know the tranmission fluid needs to be flushed, and I heard that transmission computer needs to be reprogramed? Is this true?
Our car has jerks when I put the gear into D, or I should say it has delay when I step on gas. We took our car to a dealer 2 times, and they said it's normal because it's a CVT transmission. I swear car was much smoother 2~3 years ago....
Anyway, I can flush the fluid without problems, I just want to know whether I should get tranny ecu thing.
Thanks.
Old Mar 15, 2011 | 05:20 PM
toxictv's Avatar
toxictv
For the love of Pete, never FLUSH an automatic transmission using a machine. Google it, ask a trustworthy mechanic; you'll see why.
I have never done a fluid change on the auto tranny for a mini, but as far as filling it back up, buy a fluid pump from an auto parts store. They cost about eight dollars, screw on to the top of a quart bottle and come with a long, flexible hose that makes filling up a transmission a breeze.
Old Mar 15, 2011 | 06:39 PM
jump'n'jive
i think you have some reading to do. and no one is suggesting flushing the drain. just drain and refill.
Old Mar 15, 2011 | 09:20 PM
gorillajin's Avatar
gorillajin
So I don't have to worry about reprogramming tranny ecu?
Do you guys have any DIY thread to flush tranny fluid? like what kind of fluid, how much I need to buy, etc....
Thanks.
sprp85
Aug 22, 2015 06:16 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
FLYM1N1
Aug 16, 2015 01:17 PM
