Removing fuel line from HPFP
Old Mar 10, 2011 | 06:34 PM
jacknk's Avatar
jacknk
The manual says to use special tool 130250. Has anyone had removed this line without the tool? I tried pressing in on each with small screwdrivers and that did not work. Any suggestions appreciated.
Old Feb 1, 2014 | 04:51 AM
brightside's Avatar
brightside
Need to determine if i need this tool or not for the job. Anyone ever done the job without it?
Old Feb 1, 2014 | 06:17 AM
v10climber's Avatar
v10climber
Do you have a picture of it?
Sent from my DROID RAZR HD using NAMotoring
Old Feb 9, 2014 | 02:02 PM
boOst spIKe's Avatar
boOst spIKe
special tool will help from damaging tabs that lock the feed line to hpfp. some will use hose pliers and be very gentle when applying pressure to both locking tabs. if you damage them you will have to replace the feed line as well as you may run the risk of the line not seating completely to hpfp or potentially coming off which would be no good.
silence2-38554
98
Sep 21, 2016 02:52 PM
vanhick
Aug 19, 2015 09:03 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
kpl
Aug 11, 2015 04:52 AM
