R53 stock suspension, 15X8+36, & 225/45/15s
Old Mar 9, 2011 | 07:01 PM
nametakennow's Avatar
nametakennow
I've searched a bit and am pretty sure the answer is no, but I figured I would make sure for clarity. Plus this thread will hopefully show up for future searchers...
Anyway, I've ordered a set of 6ULs in 15X8+36 form. I also have a set of 225/45/15 Hankook RS3's on the way. These will be a bit shorter than stock, but they're also only for autocross, so I'm not too concerned with the diameter difference.
With a stock suspension, will this setup require a spacer?
Thanks.
Old Mar 11, 2011 | 06:27 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Check out this thread and the links it has: https://www.northamericanmotoring.co...autocross.html
Old Mar 19, 2011 | 03:36 AM
howsoonisnow1985
@nametakennow
Did you get these?
Pics Please!
Old Mar 22, 2011 | 06:11 PM
4wheels's Avatar
4wheels
I'd be interested to hear how these work out for you. I'm considering the same setup, but debating 6UL's in 15x7.5" or Enkei PF01 in 15x8.
Old Apr 8, 2011 | 11:12 PM
KC Jr 54's Avatar
KC Jr 54
FYI The 6ul in 15x8 will require a spacer in the rear. Even though it may seem like everything clears perfectly fine while stationary, clearance change quite a bit once the suspension starts working. This is speaking from experience, as i have had the 15x8 gen2 6uls for qutie some time now. Run atleast a 3mm spacer, but the 5mm are easier to find.
ltjpunk7
Sep 6, 2015 07:32 AM
sabjcw
Aug 14, 2015 07:40 AM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
