Clutch survey. How many miles on your Mini/other clutch.
So I like many others are at 38K miles and have a slightly slipping clutch. No noises, no grinding, just slipping with throttle in 6th gear mainly.
I know some have had clutches go way earlier, but how many have had no problems past 50K miles?
I was told by my SA that 35K miles is normal for a clutch? Yeah right!? I have only had 2 cars previous (both Corolla's) and never had one need a clutch within 90K miles. I owned one for 8 years and replaced the clutch once at 130K and then never again till it was totaled at 242K (still on the original engine).
If you all could take the time to fill out this survey it would be greatly appreciated. Any make/ model is welcome as long as it was a manual transmission. Even if you never had to change the clutch while you owned it please put down the mileage when you sold it.
If you have had a clutch replaced with an aftermarket one please include a short review and mileage done on that clutch.
I will start the ball rolling.
Model: Cooper S Hardtop
Year: 2007
Mileage at failure start/ Mileage when Replaced: 35K/ at 39K not replaced.
OEM or Aftermarket clutch: OEM
Symptoms during clutch failure: Slipping higher gears mainly, hasn't gotten worse yet.
Stop go city / Open highway / Hard driving RATIO: 50/45/5
When replaced, what was the prognosis? Part Failure? Normal wear?: Not replaced yet.
Thanks.
Year: 2007
Thanks.
Year: 2007 (lease turn in)
Mileage at failure start/ Mileage when Replaced: N/A - Turned in Lease at 2 year mark w/ 30k miles on car. Clutch was ok.
Symptoms during clutch failure: N/A
When replaced, what was the prognosis? Part Failure? Normal wear?: N/A
Year: 2009 (current)
Mileage at failure start/ Mileage when Replaced: N/A - Currently at 25k miles with OEM clutch still ok.
Stop go city / Open highway / Hard driving RATIO: 35/60/5
Thanks.
So even with an AP tune you have nothing yet. I had an RMW tune for a couple of weeks, and the day it was put on I really noticed the clutch slip in 5th and 6th (too much power for it!!!!)I had to get it removed while I save for a new clutch. I will be interested to see how yours goes.
Edit. Sorry I saw that the AP it not installed yet. Anyone else with an AP?
Model: Cooper S Hatch
Year: 2006
Mileage at failure start/ Mileage when Replaced: still no problems, 67,000
Symptoms during clutch failure: No failure
Stop go city / Open highway / Hard driving RATIO: 65/30/5(track and auto-x)
When replaced, what was the prognosis? Part Failure? Normal wear?: Not planning on replacing any time soon
Year: 2006
Model: Cooper S Hardtop JCW Stage 1
Year: 2008
Mileage at failure start/ Mileage when Replaced: Clutch OK so Far at 32 K Mikes
Stop go city / Open highway / Hard driving RATIO: 10/70/20 (32 track days so far/1 AutoX)
Year: 2008
Year: 2008
Mileage at failure start/ Mileage when Replaced: 76k miles - no problems
Symptoms during clutch failure: None.
Stop go city / Open highway / Hard driving RATIO: 15/70/15
Year: 2008
Year: 2005
Mileage at failure start/ Mileage when Replaced: 64k miles - no problems
Talked to someone today driving a Just a: 140k on it, still driving the factory clutch
Year: 2005
Year: 2007
Mileage at failure start/ Mileage when Replaced: 127K, not replaced.
Stop go city / Open highway / Hard driving RATIO: 20/80/5
Year: 2007
Year: 2007
Mileage at failure start/ Mileage when Replaced: 40K (now in shop)
Symptoms during clutch failure: Racing engine in lower gear, finally couldn't move even on gas.
Stop go city / Open highway / Hard driving RATIO: 70/20/5
When replaced, what was the prognosis? Part Failure? Normal wear?: "Normal wear and tear"
Year: 2007
Model: Cooper Clubman
Year: 2008
Mileage at failure start/ Mileage when Replaced: 49K/ Appointment in a couple days to evaluate
Symptoms during clutch failure: Chatter when engaging from a stop, forward or reverse. No slip, no problem during gear changes after moving.
Stop go city / Open highway / Hard driving RATIO: 10/90/0
I'll echo the sentiments expressed by the OP: I've had cars with many, many, many more miles than this, and have never replaced a clutch on anything. I'll keep you posted as to what the SA/tech tells me.
Year: 2008
oops. just noticed this is a 2nd gen forum, just disregard.
Year: 2005
Mileage at failure start/ Mileage when Replaced: Still going strong at 89K
Symptoms during clutch failure: No simptoms.
Year: 2005
Model: JCW Hardtop
Year: 2010
Mileage at failure start/ Mileage when Replaced: 12k miles, no problems
Stop go city / Open highway / Hard driving RATIO: 60/30/10
Model: JCW Hardtop
Year: 2010
Model: Cooper S Clubman
Year: 2008
Mileage at failure start/ Mileage when Replaced: 20k miles, no problems
Stop go city / Open highway / Hard driving RATIO: 60 / 25 / 5
Year: 2008
Model: Hardtop S
Year: 2009
Stop go city / Open highway / Hard driving RATIO: 80/15/5
*******THIS IS ABOUT THE ONLY THING THAT HASN'T BROKE YET*******
Model: Hardtop S
Year: 2009
Year: 2007
Year: 2007
WOW!!!!And the winner is....
Year: 2008
Year: 2008
Clutch 1:
Model: Cooper S
Year: 2008
Mileage at failure start/ Mileage when Replaced: 30kish / 30kish
Symptoms during clutch failure: Really weird engagement, jerky. Clutch itself was fine, no slippage.
Stop go city / Open highway / Hard driving RATIO: 75/25/and I'd say 50% of my driving is hard driving
...also have had a tune since just before 30k miles, and a bigger turbo for the past 10k miles.
When replaced, what was the prognosis? Part Failure? Normal wear?: Throwout bearing/pressure plate/flywheel issue (don't remember the exact issue to be honest)...clutch was still within spec. But all parts were replaced under warranty...clutch included.
Clutch 2:
Mileage at failure start/ Mileage when Replaced: 51K / current issue, not replaced as of yet...
Symptoms during clutch failure: Rattling flywheel at idle, stops when clutch is pushed in. Clutch holds fine though, no slip. Even with ~260 ft-lbs to the wheels.
Stop go city / Open highway / Hard driving RATIO: see above
When replaced, what was the prognosis? Part Failure? Normal wear?: Taking it in Thursday.......
Model: Cooper S
Year: 2008
...also have had a tune since just before 30k miles, and a bigger turbo for the past 10k miles.When replaced, what was the prognosis? Part Failure? Normal wear?: Throwout bearing/pressure plate/flywheel issue (don't remember the exact issue to be honest)...clutch was still within spec. But all parts were replaced under warranty...clutch included.
Clutch 2:
Year: 2007
Thanks.
Year: 2007
Thanks.
make/model/year: 2005 Infiniti G35
OEM clutch
mileage at start of symptoms: just over 50K
symptoms: slipping for G35
mainly stop and go driving-65 or 70 highway, 30-45 city
clutch not replaced; opted to trade in car instead of repairing
prognosis: normal wear.
I also had an Infiniti G20 that went over 50k miles before needing clutch replacement. I replaced it with OEM clutch just before I sold that car at 70k miles.
Year: 2008
Stop go city / Open highway / Hard driving RATIO:40/55/5
Continues to be fine. I've never had clutch issues while driving pickup trucks to 18 wheelers for thirty five years. I hope to keep it that way!
Year: 2008
Well... I took my Mini to Universal Mini today for an "excessive battery discharge" message. They asked if there was anything else I wanted them to look at. I mentioned a weird "sigh" or "hoot" noise when taking off from a standing start. They came back with it being the clutch and said they could have it done by tomorrow. I asked how much, expecting to hear the $3000 price tag. They said "NOTHING!!!!!" under warranty!!!!!! WOW!!!!
Needless to say I said go ahead. Very happy about that one.
On a side note, I have a 2011 Hyundai Sonata rental, and it is pretty sweet. Much better than my Mom's Hyundai Excel from many moons ago. Hyundai have really picked their game up. But still nowhere near as fun as the R56S!!!
Year: 2009
Mileage at failure start/ Mileage when Replaced: 67,000 miles no slipping or other wear signs. I hope it lets go before the 100k maintenance plan is up.
Stop go city / Open highway / Hard driving RATIO: 50/50 all with brisk acceleration
Year: 2009
