R50/53 Engine Cooling Fan 1plug/2plug
Old Mar 6, 2011 | 09:26 AM
JMGR33N's Avatar
JMGR33N
Hi guys, Another fan related post I'm afraid.
I've been a bit of a ***, I needed a new cooling fan as the resistor in my old one's popped. So came across a brand new OEM one on Ebay pretty cheap, advertised as a pre 03/03 part(I've got a 52 reg S). local MINI Stealers wanted £240!
Well part came, Brand new, ONLY ONE CONNECTOR though. (I have the large Connector and the small 2pin one) My fault, I should have checked in a bit more detail before buying it.
But then I was having a think about it, the only difference is that this new one is missing a relay and the two pin plug and wires. So... I'm thinking about just pinching these off the old one(I've tested the relay and it's fine) and fitting them onto the new one.
It'd be pretty easy to do, and the new fan assembly has all the mounting points where the relay would have been on an earlier model.
What do you guys think?
**Update** checked the the part number on RealOEM and it looks to be the correct one.. hmm?
James
Kimolaoha
Jul 5, 2023 01:04 PM
cerenkov
Apr 24, 2018 07:47 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
