Way off topic, 84 FJ60
Ok, so I know nothing could be more different from a mini than an 84 toyota FJ 60 landcruiser. well, maybe a Mercedes Benz unimog. I figured i'd post a little problem i'm having with one here since there are lots of car minded people here. anyways, enjoy my misery, and hopfully, have some suggestions.
Are way more complicated than I had imagined. Here's the story and I'm hoping that someone can help out a bit. SO my friend says his 84 FJ60 needs some work and I volunteer.
The worst problem is a noise in the front brakes. I track that down to being him having almost zero friction material. Here is where everything goes horribly wrong. I look a the caliper and say ok, these 4 bolts must be the ones I have to remove. of course not, So, after I get those out and the two i was supposed to remove, I notice that the pad pins are frozen. I spent a good deal of time trying to free them before cutting the end off and pushing it out with a chisel. There is no damage to the caliper, execept for the fact that it came out in 2 pieces? Why does toyota use two piece calipers?
I guess the main questions are:
what is the best way to put the caliper back together?
how do i get those pins out easily?
can i get a caliper kit with pins and grommets so i can put the caliper back together? or should i try to find a loaded caliper?
Other than that I'm really impressed with this truck. Thing starts and runs like a champ. The interior is super clean. the biggest problem is it has a good amount of body rust.
Gotta love those FJs, the 40, 55 and 60 are all favorites of mine. As it appears that the calipers have been taken apart, I'd just send them to a brake specialist like White Post Restorations and have them sleeved or honed prior to reassembly. Especially if rust is a factor like it was indicated in the post.
Ha, I felt there was no love for the FJ.
well after some debate on another site i ended up ordering a set of loaded calipers for my friend. Nothing like throwing money away on a hobby car. well, we can understand can't we?
