Suspension R56 IE Fixed Camber Plate Install Issue
Old Feb 12, 2011 | 04:59 AM
DOC4444's Avatar
DOC4444
[FONT=Arial][SIZE=2]I just had a shop install the plates and align the car. The box they came in did not have instructions in it. Several thin washers were included. The tech did not see any reason to use them, so he did not. [/SIZE][/FONT]
[FONT=Arial][SIZE=2][/SIZE][/FONT]
[FONT=Arial][SIZE=2]Should he have and if so, what is the purpose of them?[/SIZE][/FONT]
[FONT=Arial][SIZE=2]Thanks,[/SIZE][/FONT]
[FONT=Arial][/FONT]
[FONT=Arial]DOC[/FONT]
Old Feb 12, 2011 | 05:01 AM
DOC4444's Avatar
DOC4444
What's with the way the above post is displayed?
DOC
Old Feb 12, 2011 | 09:24 AM
slinger688's Avatar
slinger688
DOC
You probably used MS word to type the note and pasted it here. So the xml tags are displayed.
Old Feb 12, 2011 | 09:26 AM
slinger688's Avatar
slinger688
Do you have a pic of the washers? What size are they?
Not sure what they can be for the fixed camber plate. I have their adjustables and the washers are for the adjustment bolts.
Old Feb 14, 2011 | 10:33 AM
andyroo's Avatar
andyroo
Are they the 6 washers to be used with the (3 per side) locator studs that come through the strut tower? You should probably use those, luckily that's something you can do in about 5 minutes yourself without putting the car up.
- Andrew
Old Feb 14, 2011 | 10:39 AM
DOC4444's Avatar
DOC4444
Jeff Ireland emailed me and indicated the washers were just to go under the supplied nuts. We used the OEM style nuts, so we did not use the supplied washers. I thought they might be for some sort of required shimming, but I guess not.
DOC
Old Feb 14, 2011 | 10:41 AM
andyroo's Avatar
andyroo
Yup, that's what I meant. You're good then.
- Andrew
Old Feb 14, 2011 | 12:29 PM
gkp's Avatar
gkp
FYI -- I was told by a vendor that IE doesn't include installation directions because their lawyers advised them not to. Insane. I'd think there's more liability by NOT giving instructions, but I guess that's why I'm not a lawyer.
Old Feb 14, 2011 | 04:17 PM
DOC4444's Avatar
DOC4444
Hey gkp,
My very first car was a 1960 Austin 850 Mini which I got when I was 15.
DOC
azntaiji
Aug 13, 2015 03:24 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
