Suspension Front Swaybar Bushing Bracket question
Old Feb 9, 2011 | 02:01 PM
BruceWarne's Avatar
BruceWarne
Hi all
While I was under my car over the weekend I noticed that my one front(powerflex) swaybar bushing wasn't seated perfectly. It seems sort of squashed out of shape on the one side - and is not protruding as far from the bracket as I think it should.
Now, my question is this: I know to install these bushings requires dropping the front subframe. But, do you think I might be able to loosen the bracket enough to pop the bushing into place (without dropping s/f)? One of the bracket bolts looks like it's easy to get at with a normal box-wrench...the clearance on the other one looks pretty tight though.
Any tips/advice?
Old Feb 9, 2011 | 04:20 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That's what we would do here at the shop, try to loosen the bolts that will be easier than lowering the entire subframe.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
gmonde
Sep 8, 2015 06:37 AM
Etrain
11
Aug 20, 2015 10:22 AM
FLYM1N1
Aug 15, 2015 11:20 AM
