R56 Fob Settings Forgotten
I have a '11 with Connected/NAV and Comfort Access.
Yesterday when I drove the car, all of the unique fob settings had been forgotten, including redio presets and turn signal preference. Today, my girlfriend's settings all worked on her fob. I have not had a chance to try my fob again to see if maybe they have come back.
Has anyone seen this before or know why it would or how it could happen? It is quite annoying.
Thanks, Pete
Thanks, Pete
Beat me to it..... I had the same issue when I first got mine. I still haven't programmed the other Fob......
Thanks, Pete
Thanks, Pete
It is not enough to just get in the car with a different FOB, even if you start the car and drive off. Also if the engine is running it's too late.
More than once I have found myself at a stoplight quickly turning off the engine, pressing unlock on my FOB, and restarting just to get my settings.
Our problem is that we often do not lock the car in our own driveway. Not very convenient for me or especially those who park in a locked garage and have no need to lock the car at all.
It was definately my fob. Both FOBs are programmed. There were, for example, no radio presets and not my girlfriend's presets (which are different than mine).
You have to actually UNLOCK the car using either the CA door button OR the unlock button on the FOB that you are going to use.
What happens if you put the other fob in the dash socket? Will that change your settings to the desired set?
Was it a one time only deal?... or did you have to reprogram everything to your FOB? Was the battery removed from the FOB in that time? Not sure if it looses settings or not if the battery is removed?
dscott90000
Sep 9, 2015 07:55 AM
OutMotoring
Sep 8, 2015 06:27 AM
