How To READ BEFORE POSTING How-To forum purpose and requests
Old Jan 14, 2011 | 10:27 AM
Motor On's Avatar
Motor On
The How To forum is a place for threads dedicated to explaining how to accomplish, tweak or modify something on your Countryman.
If there's something that you don't see a thread for in the How To forum, please post a request for it in this thread so others can check it and make it if possible. Do not start a new thread asking for a how to for something, so that when people see a thread with a particular subject they'll know that it will contain directions from the get go.
Also please note to make sure this format is maintained; all new threads in this forum do require moderator approval before the display in the forum.
Old Mar 10, 2011 | 04:03 PM
chessie1629
oil change
How do you change the oil filter without spilling oil everywhere?
Old Mar 17, 2011 | 10:45 AM
03mini-S's Avatar
03mini-S
Remove the oil pan plug to start draining then loosen the filter case but don't remove it. Leave it on by the last thread or so. This will allow air to be drawn in and pull the oil down into the engine.
Old Mar 20, 2011 | 06:59 PM
Longley01's Avatar
Longley01
Oil Change -- 4 questions:
1. Quanity--is it same as Gen II guys 4.4 quarts?
2. Torques -- same as Gen II guys as well?
Oil pan drain plug = 22.0 lbs/ft
Oil filter cap = 18.5 lbs/ft
3. Has anyone used / have experience with oils from http://www.renewablelube.com/motoroilsHP.htm ?
4. Has anyone found a good service manual for the Countryman?
As always, thanks for the help!
Old Jun 13, 2011 | 04:44 PM
JoniF's Avatar
JoniF
Has anyone changed out their sidescuttles? I just got mine in and doesn't have clear directions. I'm hoping I can install this myself and not have to pay at the shop.
Old Jun 18, 2011 | 09:44 AM
dogmasue's Avatar
dogmasue
Does anyone know how to remove the SPLIT REAR CENTER RAIL? (see photo)
I need to remove it in order to create a lower platform for my Dog crating and I don't know where to begin
TIA!
Old Jun 18, 2011 | 07:46 PM
dogmasue's Avatar
dogmasue
i figured it out
once i slid the rubber insert towards the front of the car, it exposed the first screw head. it was all downhill after that!
(or should i say about a dozen screw heads downhill after that!)
Old Jun 23, 2011 | 10:05 AM
Newdl's Avatar
Newdl
Dogmasue,
I am sorry I did not see this sooner...I look mine out this past weekend. I am also having a center fill piece made in the Kent area by an interior shop that I know and trust. This will fit between the two existing seats and create a bench style seat.
Interested?
P.S. I didn't remove my rear seats to pull my rail out... That must have been a ton of work!!!
-Newdl AKA Neal, your MINI Motoring Advisor
Old Jun 23, 2011 | 08:28 PM
dogmasue's Avatar
dogmasue
hey neal! you are popping up everywhere!
chris took the back seats out (for good, not just for the center rail removal) -- they didn't seem to be a problem.
i'll be installing custom dog crating in the rear seat area as soon as i get them designed and ordered. for now, this will have to do, but it is only good for one dog:
Old Nov 25, 2011 | 03:54 PM
northbarts's Avatar
northbarts
Does anyone have tips for changing the motor oil in my 2002 Mini? I,m doing the service this time instead of the shop this time around.
Old Nov 26, 2011 | 07:10 AM
chrunck's Avatar
chrunck
You're in the Countryman section of the forums, so you're not going to find anything here. What you want is the 1st Generation how-to forum here: https://www.northamericanmotoring.co...ms/how-to-340/
Old Mar 4, 2012 | 12:29 PM
rfath's Avatar
rfath
Request: dash take-apart for wiring iphone mount?
I'm a lemur and didn't get the armrest/iphone snap-in. I DO have the cravenspeed mount and an extra-long extender cable and a need to thoroughly frustrate myself, apparently.
Does anyone have any hints for dash pull-apart to run the extender inside?
Old Aug 5, 2012 | 04:21 PM
Weare138's Avatar
Weare138
Has anyone changed their brake ducts? Care to share install tips?
Old Aug 24, 2012 | 04:12 PM
KidLuck's Avatar
KidLuck
anyone have any info on changing the spark plugs?
Old Sep 22, 2012 | 12:50 PM
Hujan's Avatar
Hujan
How to request: How to remove lower plastic grill?
How do you remove the lower plastic grille (the one in front of the intercooler)? Ideally, I'm wondering if it can be done without removing the bumper. Thanks!
Old Oct 8, 2012 | 06:23 AM
countryman-s's Avatar
countryman-s
If I remember correctly its part of the front bumper. You would have to cut it out you would have to remove the bumper, and it's a pain in the butt
Old Jan 20, 2013 | 08:22 AM
devinkato's Avatar
devinkato
How do you replace headlight bulbs and adjust aiming angle?
Old Feb 5, 2013 | 12:11 PM
iriedevil32's Avatar
iriedevil32
How do you remove the side scuttles on the Countryman S?
Old Mar 6, 2013 | 08:28 PM
rayzmini's Avatar
rayzmini
Unhappy how do you change the front turn signal bulb?
Howdo you gain access to change out those ugly orange turn signal bulbs please advise!
Old Mar 23, 2013 | 09:13 AM
Weare138's Avatar
Weare138
How do you pop off the Mickey bezel around the speedo and vents? And also how to pop off the left and right vent pods?
Old Mar 23, 2013 | 09:24 AM
Hujan's Avatar
Hujan
https://www.northamericanmotoring.co...dash-trim.html
See post #8.
Old May 9, 2013 | 10:48 PM
jakers's Avatar
jakers
I'd like to post a how-to on trailer wiring. I've searched high and low for good instructions for a 2011 All4, but I haven't found anything comprehensive. I finally got mine working, and I'd like to share what I did in case some other people run into the same stuff I did.
Old Nov 4, 2013 | 12:33 AM
RonkyOne's Avatar
RonkyOne
My remote control for gate
inserted in the ashtray, which does not use
Attached Thumbnails READ BEFORE POSTING How-To forum purpose and requests-20131101_193000.jpg   READ BEFORE POSTING How-To forum purpose and requests-20131101_190147.jpg   READ BEFORE POSTING How-To forum purpose and requests-20131101_190304.jpg
Old Nov 19, 2013 | 02:05 PM
Big K's Avatar
Big K
Red face Removing rear light trims
So I had a 07' Cooper and had no problem removing rear light trims, now I own a Countryman and attempted to remove the rear trims and broke some tabs and actually broke the trim at the bottom. If someone could share some pics and useful info on how to remove these would be great!
Old Nov 23, 2013 | 04:14 PM
chrunck's Avatar
chrunck
There's a thread here somewhere with directions on removing the rear trim. I'll see if I can find it.
