R56 Got a rattle / creak / squeak from the sunroof? PROBLEM SOLVED.
Old Jan 13, 2011 | 05:55 PM
toolazyforalogin's Avatar
toolazyforalogin
So my Mini has been to the dealer a dozen times or so for a rattle / squeak from the sunroof area. Last week I realized that if I pushed upwards (towards the sky) on the rear glass the sounds typically stop....so what could be causing this ridiculous sound (especially on concrete)....well it turns out that the mesh screens that slide in and out are not only made of cheap plastic but are also mounted on plastic rails.....
So I asked my dealership to take out my screens. Voila, I no longer have any sounds coming from the sunroof.
I would highly recommend taking them out to anyone that does not need them...since my sunroofs are tinted at 5% I do not have any need for them.
I finally had a peaceful ride into work today.
Old Jan 13, 2011 | 10:39 PM
KevinC's Avatar
KevinC
Give it about a week.
Old Jan 14, 2011 | 02:36 AM
Toad S's Avatar
Toad S
I had rattle that sounded like a canister of CO2 on a tin can especially when cold. It was horrid rattle and maddening... Apparently the sunroof has a positional adjustment, and can be trued up. It was bizarre rattle, from sunroof itself, but with a second visit and then another that day with the tech, I was able to get them to drive it cold and the rattle was obvious!
Cheers!
Old Jan 19, 2011 | 01:02 AM
side car's Avatar
side car
My rear sunroof started squeaking after only a few hundred miles; tomorrow I'll eagerly try this out
Old Jan 19, 2011 | 04:57 AM
Augie05's Avatar
Augie05
Interesting. Mine makes a rattle noise that appears to be coming from the rear window area when it is totally closed tight. When I tilt it up just a hair then the rattle stops. I wonder if the rattle is coming from the screen materials.
Old Jan 19, 2011 | 05:30 AM
MCS Fever's Avatar
MCS Fever
Why not lube the plastic slides with some rubber / vinyl treatment......
Rather than throw out the baby with the wash (we LIKE the screens even with added tint).
maestro39
Oct 27, 2015 02:38 PM
alistaircookie
Oct 8, 2015 10:52 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
iclancy82
Aug 11, 2015 09:35 AM
