R56 wiper blades are poop
I just drove my car in the rain/snow for for the first time yesterday and the windshield wipers were horrible - bad enough I almost had to pull over. They just smeared the water all over without removing it cleanly at all. This was for both front blades (the back on works pretty good). Are the stock blades just crap or do I need to go back to the dealer?
Thanks,
-Alex
Thanks,
-Alex
Have you used your wipers/washers much since getting your MINI?? How did they perform then?? I'm not in the Snow Belt by any means, but I do protect my wiper blades with 303 Areospace Rubber & Vinyl Protectant, keeps them plyable and streak free for the 6mo. they are on, then I go to the Dealer and have them replaced. I also make my own Washer Fluid with 303 Instant Windshield Washer Tablets!!
I've heard of others who do not like the Auto-Sensing Wipers, I on the other hand L@VE them, being in the PNW they are a necessity. You could syphon out the Washer Fluid and I either make your own like I do, or try the various forms of De-Icer Washer Fluid, either way I would put something on the Blades to lube them a bit, this should help a great deal.
MINI the Poo
Clean the windshield and the blades..... and run the blades a lot - they need to break-in a bit.
I would replace them ASAP, but not bother replacing them with OEM, they are pretty much poo.
Try the PIAAs in my sig, Amazon is a good source.
Wiper blades:
18” Driver, 19” Passenger
PIAA Super Silicone Curved: 93245 & 93248
Wiper blades:
Treating the windshield makes a big difference to me. Rain-x or for me the goo that came with the PIAAs. On the highway, in light rain (not at night because of the streetlamps) I can leave wipers off and it just beads away.
I've always asked them to replace Molly's Wiper Blades, whether I have to pay for them ($11 for all 3) to be replaced or not. Yes, they'll replace them once a year for Free under the Free Maintenance Program, so I just pick up the tab for the other times I've asked to have them replaced.
Blades should last 12 months if they are not poo. He has a 2011 for crying out loud.
I just hope they don't toss my PIAAs with MINI the poo blades when we go in for the July oil change....
The car is shipped with a cosmoline type of spray on the wind shield, They do nothing to protect the wipers when they put it on and generally the transport company will turn on the wipers to see out of the windshield when they need to move the cars around causing the goop to get on the wiper more. If you get a new Mini clean the wiper with something like alcohol before you need to use the wipers..
CLEAN the glass
I run mine with a razor blade twice a year and anytime the wipers begin to hang up or streak.
Done carefully there is less danger to your glass then there is to your fingers. Properly razored, your glass is ready for windex and any other crud you want to put on it. The windex IS important as this ammonia cleaner WILL finish the cleaning, and anything else just clouds the issue (pun intended) but I have been an occasional fan of Rain-x and similar products.
I've done the rain-x, and the piaa and nothing beats razor blade at 6 months and new blades from a decent brand.
You're gonna be amazed what comes off your glass the first time you run a razor over it. And a squeegee - that's all ww wipers are - works WAY better on smooth surfaces.
Paint scraper at your local hardware - I pay 95 cents for a single edge razor in a plastic handle . . .
the car is 3 weeks old! i put rainx on today and i've decided against ordering new blades. the current ones look fine and i've cleaned them each time i've washed the car. I guess they've sourced a new supplier for the blades or my contact angle is just wrong. either way, this is a part that should work and i'm going to go down to the dealer and see if a replacement makes them not suck.
masavacool: That's not a bad idea. They probably figure that almost no one actually replaces them like you do
Actually, when I first started using them... you could call their phone number, and they'd ship you a new set for nothing. But I only managed to get that to happen twice.
masava: haha!
striped toad: i've never thought of using wax on the glass. Actually, I didn't believe you (at first) but a google search confirms this isn't a crazy idea
. I'm ready to try it next time i wax the car (still unnamed :/ ) . anyone else do this?
When my MINI was new I clayed the windshield (all the glass actually) and applied wax to it. I usually clay the windshield about once a year to get the more stubborn stuff off. Wax every time the car is waxed (twice a year) and of course Hydro treatments in between.
For normal cleaning I use either Invisible Glass or Sprayway Cleaner, whatever I can get my hands on when a bottle runs out.
Ditto on the recommendation to keep the glass clean to help improve the performance of the wipers.
A long time ago my father taught me to use some sandpaper on the wiper blades to get crud off of them. Not sure whether that is advisable with today's blades. Haven't had to go that route. I do make sure when I wash the car to run my wash mitt along the blades themselves a couple times to at least knock off anything on the surface.
I won't exactly say that Mini's blades are "poop", but they're not the worst things in the world either. Try the ones Toyota supplies!
It really sounds like you just got a set of blades that prematurely dried out. Rubber materials, almost all of them, have a shelf life and a working life. There is no telling how long the blades on your car sat around the factory prior to being installed on your car.
I personally like the Rain-X blades. Here in New England the salt and sand destroy wiper blades and it's nice to just go to a Wal-Mart and get a new set.
You are so tight, you squeek!
At least your wiper blades don't.
