R56 End of Maintenance Warranty drop off - software question
Old Jan 5, 2011 | 09:48 AM
mkortering5's Avatar
mkortering5
So my Maintenance Warranty ended today and my car is done at the dealership. It had the following done:
-New clutch
-New high-pressure fuel pump
-Fixed rattling in the door
The other thing that was done excites me:
-"updated software programming"
Anyone know what that means?
My car is a 2007 MCS, 6MT, sport pack, cold pack, premium pack, all the goodies...
thanks!
Old Jan 5, 2011 | 10:21 AM
eR1c's Avatar
eR1c
-i assume they are updating the software ...hopefully that means that our car's bluetooth will be updated (to work w/ my HTC android phone)!!
Old Jan 5, 2011 | 06:02 PM
Craysv1's Avatar
Craysv1
Was your clutch covered under the warranty?
Old Jan 5, 2011 | 07:12 PM
mkortering5
Under the maintenance warranty, yes.
Old Jan 5, 2011 | 08:43 PM
Craysv1's Avatar
Craysv1
3/36k? I didn't know that covered clutches!
Old Jan 5, 2011 | 09:12 PM
RJKimbell's Avatar
RJKimbell
We have the HTC Evo...no problems with Bluetooth at all, which HTC Phone do you have??
Old Jan 5, 2011 | 10:12 PM
fishbert's Avatar
fishbert
It does.
The issue arrises if they believe the part failed due to improper use.
Old Jan 6, 2011 | 04:46 AM
richardsperry's Avatar
richardsperry
Again, two different things.
Maintenance is oil changes and other fluids, brake pads and rotors. 3 years 36K miles
Total vehicle warranty would cover mechanical systems and parts replacement. 4 years 50K miles.
No way a clutch is covered by maintenance.
Old Jan 6, 2011 | 04:54 AM
Walt's Avatar
Walt
If the Maintenance covers wear items like brake pads, why not clutches?
Old Jan 6, 2011 | 05:23 AM
yetti96's Avatar
yetti96
Depends on the dealership and how hard the want to argue with MINI USA. I have an auto but asked if the clutch was covered under the maintenance and he said it was if not deemed from abuse, but rather failure.
Old Jan 6, 2011 | 06:21 AM
fishbert's Avatar
fishbert
I was not confused on this point. Clutch is covered by the 3/36 maintenance plan, so long as it's a failure due to normal wear and not abuse. The 4/50 warranty does not cover wear of the clutch, as it's a part designed to wear over time (like brake pads, tires, etc.).
Go look at the "Extended Maintenance and Warranty Program - 6 year 100k miles Contract Terms" sticky in this forum. The clutch is specifically called out alongside brake pads, wiper blades, etc. in the 'Coverages' section of the agreement.
Old Jan 6, 2011 | 06:41 PM
mkortering5
Clutch is part of the Maintenance Warranty (3/36k). Trust me, I literally just had it done. Wasn't due to improper use, just wear and tear.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
gmonde
Sep 8, 2015 06:37 AM
minipopkart
Aug 13, 2015 05:22 AM
