R50/53 power stearing is gone
Old Dec 30, 2010 | 11:31 AM
freeskier's Avatar
freeskier
after filling the resevoir several times, i think my pump has let go. has anyone else had this problem? i switcheD to lucas PS STOP LEAK and it slowed the loss of fluids but it may have toasted my pump. what should i do first?
Old Dec 30, 2010 | 11:44 AM
ZippyNH's Avatar
ZippyNH
You might now need a new pump and a new steering rack...
Mini PS fluid is not compatible with standard ps fluid...which is what was in the leakstop....it softens the seals in the rack, and likely will cause it to fail.
A very $$$ mistake. You might get lucky and flush the P's system, maybe put on a new hose and be ok...or perhaps the rack was what was leaking...
But never use anything but the Petrosin CHF-11S fluid (look it up, I'm 90% sure, but petrosin makes 2 or 3 similar named fluids). Mini, BMW, vw, and some NAPA, etc stores stock it.
Old Dec 30, 2010 | 01:05 PM
perucho's Avatar
perucho
Originally Posted by freeskier
after filling the resevoir several times...
What did you use to fill it up repeatedly? Hopefully not regular PS fluid...
Old Dec 30, 2010 | 02:15 PM
IsquintsI's Avatar
IsquintsI
My power steering is starting to make noise everytime i turn the wheel.. I was wondering am i starting to have this problem too or is my pump just going bad?
Old Dec 30, 2010 | 03:23 PM
Curbiecooper's Avatar
Curbiecooper
I have an '02 and I had to get my pump replace a couple months ago . It was a very costly fix for sure. When I got it, it had the nosie to it and now it doesnt so I am thinking that i had a slight problem before it decided to finally just give out out. Better get it checked out soon. Good Luck
Old Dec 30, 2010 | 07:36 PM
freeskier's Avatar
freeskier
im gonna drain everything and try to put some of the correct fluid through it. if that doesnt work ill swap the pump.
Old Dec 30, 2010 | 07:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the only P/S fluid to use is the CHF 11s
Here is what it would look like:
http://www.waymotorworks.com/product...cat=342&page=1
The power steering pumps are pretty common to fail.
Old Dec 31, 2010 | 01:44 PM
ZippyNH's Avatar
ZippyNH
PS...find the scource of the leak...
It might be a pump issue, but it could be a hose or a seal on the rack...
Just pouring more oil into a system with a leak (that may have already been dammaged by running it dry, and/or the wrong fluid) is just a waste of money...just dripping your money onto the road!!
A simple $50 hose replacent might now need a $500+ pump and a new rack...$2000+!! not likely, but of you spend less, consideryoueslf lucky!!
Old Jan 15, 2011 | 05:09 PM
modimum's Avatar
modimum
This was a known issue with the '04s, I think. Thankfully mine started to fail under warranty, in the last 5k or less of warranty at that.
Old Jan 15, 2011 | 05:11 PM
modimum's Avatar
modimum
This was a known issue with the '04s, I think. The motor would go out intermittently. Thankfully mine started to fail under warranty, in the last 5k or less of warranty at that.
bADbOYbECK
41
Oct 16, 2015 12:39 PM
twriter
Oct 2, 2015 03:14 PM
paul7878
Sep 14, 2015 07:44 AM
Emnotek
Sep 11, 2015 04:16 PM
Ntety
Sep 2, 2015 08:39 PM
