R56 Bad Thermostat?
Old Dec 7, 2010 | 10:46 AM
izzyj's Avatar
izzyj
Bad Thermostat?
Greetings,
I've gotten a problem today that is very similar to what I had about a year ago around this time. R56 MCS takes a while to start heating up, its freezing my ankles for about 30 minutes before it gets working again. When this happened last time it happened for a while before the CEL kicked on, I just got the CEL today with the same symptoms. Dealer replaced the thermostat under warranty before, but at 56k miles I'd have to eat the cost (if it truly is the thermostat) Also after the short drive I did (while freezing my ankles) the Fan kicked on after turning of the car (its 17F outside I don't think it would overheat on a 5 minute drive)
So I'm wondering.. Could it be the thermostat again? Do you think I could get the dealer to do something about it (seeing as this was a previous issue?)
Thanks,
Izzy
Old Dec 7, 2010 | 11:11 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've replaced several thermostats on the R56 already. If they did it before and it failed it should still be under warranty. All MINI parts carry a 2 year parts warranty.
Old Dec 7, 2010 | 12:28 PM
izzyj's Avatar
izzyj
Thanks! That should probably cover the labor as well no? If not I'm guessing it won't be too bad... Although they do like to take their sweet time...
Rohdeandschwarz
May 16, 2019 08:59 AM
genik
Oct 4, 2016 08:36 AM
Rohdeandschwarz
Nov 5, 2015 07:58 AM
olson187
Sep 18, 2015 10:26 AM
