Suspension A Tire Question
Old Dec 5, 2010 | 02:10 PM
ice91's Avatar
ice91
A Tire Question
HI,
I got a 2007 R56 with H&R springs. The thing is lowered pretty much to the ground. It has the JCW Double Spoke Black Rims 18 inch. I changed the front tires to 225/40/18 that tire is massive and looks great, but when i turn the steering wheel completely to one side it seems to rub with a plastic cover it has inside the bumper. I just need a little tiny bite of clearance.
Has anyone had issues with this? How can I solve it?
Old Dec 5, 2010 | 03:29 PM
Mini Fireman's Avatar
Mini Fireman
Plenty of us have rubbing issues to various degrees. It's not a big deal depending on what you are rubbing on.
1) Let it rub until it self-clearances.
2) Go back to stock height (you're not as low as you think if you are only on springs).
3) Go to a smaller tire size.
4) Install the JCW steering stops.
5) Stop turning when you hear it start rubbing.
Old Dec 5, 2010 | 06:26 PM
TylerF's Avatar
TylerF
JCW Steering Stops?
What are those?
Old Dec 5, 2010 | 07:40 PM
Jim Michaels's Avatar
Jim Michaels
Tyler: Steering stops are a cheap fix for the rubbing at full lock that lowering and wider tires often cause. They restrict the turning angle to full lock, thus preventing the tire from ever reaching the point where it would otherwise rub. The downside is that they also increase the turning radius of the car.
Old Dec 5, 2010 | 09:07 PM
hunter99's Avatar
hunter99
If you notice he has a '07 newer body style. Are the JCW stops available for them. I have no idea and you may be spot on. Just wanted to mention it incase it was missed.
Old Dec 8, 2010 | 07:18 AM
Jazzop's Avatar
Jazzop
Why don't you ask your question in the R56 forums?
Old Dec 8, 2010 | 01:06 PM
Mini Fireman
Yes, the stops are available for the R56. See the PDF linked in this article for the part number: http://www.motoringfile.com/2008/10/...ring-stop-diy/
The PDF link: http://www.motoringfile.com/wp-conte...ering_stop.pdf
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Emnotek
Aug 13, 2015 05:47 PM
jrezzo
Aug 9, 2015 10:32 PM
